Jim
- Dec 18, 2019
- North Carolina
- Essex 4543
- Spartan
- Cummins / I6 Diesel Pusher 605HP
- 2016 Jeep Rubicon
I understand, and thank you. But why would I want, or need, to do any of the above?Auto will "raise" (take pressure off the wheel) when in reverse
Disable prevents the above
Manual raises the tag
Keep from dragging the tire I suppose doing sharp turns. While I have HWH Active Air and the tag dumps automatically which doesn't necessarily mean the tire raises, this may be what the result was:I understand, and thank you. But why would I want, or need, to do any of the above?
If you snowbird the way @Neal does, there may be times you need extra traction on the rear drive axle. Lifting the tag will shift weight there.I understand, and thank you. But why would I want, or need, to do any of the above?
