New DEF?
jagpot
California
King Aire
Cummins
Jeep Wr Sahara
Just got back from the world wide Con-Ag convention Las Vegas. Came across a vendor for DEF. They were proud and pushing their Platinum version. New and improved version. Really? This one is supposed to add a new proprietary ingredient so the DEF does not form crystals that build up in the exhaust and create a block increasing backward pressure. It is about 6 bucks more than the regular DEF. Any thoughts on this???? They say this could help with the head problem. Don't know if I'm buying into this yet.
Blue DEF Platinum had been around for a couple of years and they claim the same thing, wont crystalize. I bought some of each and did a side by side test in a dish, just letting it sit out in the open air and the Platinum actually crystalized worse than the standard. What company is claiming this now.
Can't remember what company. Do you use BLUE or another brand?
I almost exclusively DEF from truck stops, Loves, Pilot, ect in my coach. When Blue Def came out with the Platinum I considered switching until i ran the test. I have a diesel pick up that I exclusively use the standard Blue DEF in the 2.5 gal jugs.
It would have been nice if Newmar put the DEF Tank on my DS on the same side as the pump as where I am already sitting there getting diesel. :mad:
Well. They did…eventually. My 2017 is correct. Not sure what they were thinking back then.
I find box DEF more convenient as there is rarely an opportunity to fill both tanks from the same position at the pumps, and with box DEF I can add it at my leisure, at home or in a CG. I don’t bother with it when getting fuel.
Since I get 300 mpg I don’t have to add it very often, and always having it on hand makes it easy to keep the tank full, reducing the chance of crud build-up in the tank and on the header. And then of course there is the ability to determine how old it is, if you can keep up with the ever-changing date codes.
I buy from my local Chevron card lock station as they don’t jack up the price like so many big box stores. I commonly see it for $20-25 a 2.5 gal box in stores these days. Still $12 at Chevron.
What does pump DEF generally cost these days?
I think it‘s commonly on the passenger side on side radiator coaches. My ‘16 Ventana has it on the driver’s side too. Either way, its never next to the fuel fill like it is on my F250, so to fill both from the same position, you’d have to find pumps positioned just right.
One of the advantages in the SuperC - DEF is immediately next to the fuel tank on the driver’s side.
I don’t understand what these nice class A builders were doing when they designed the units. We know they weren’t thinking as actual drivers in the real world. These builders need to make the designers drive one of these class A units through a truck stop to do a fuel and DEF fill up. That should solve the issue.
They just build a coach on the chassis as delivered. They’d have to modify it to make an improvement in tank location and that would take time and money, and probably some level of EPA approval. So really its the chassis manufacturers who would have to make the change. I can see how it would be much more tidy on a Super C since they start with a cab and chassis truck.
Take a look at the before and after on mine - they just worked around the tank wasting a lot of storage space. But that compartment wouldn’t even be there on a side radiator coach.
I agree with @Rich W. I also use the jugs, always have, something to do while enjoying a cold one at the campground, the pumps are a PITA in my opinion
I think the DEF tank needs to be near the engine/exhaust which dictates its location.
I hadn’t thought about that but it makes sense because that’s where it is whether its a class A or super C. Maybe pumping DEF the length of the chassis would be more problematic than it already is.
I suspect it would be hard to keep that line from freezing in the winter….
