Question How to figure out which battery I need?
Rosy
RVF Expert
Alberta, Canada
Coachmen
Freedom Express 25SE
28 ft total; 25 ft box
2020 Toyota Tundra
I suspect this is probably a stupid question but I need a new battery and I'm not sure how to figure out what size/rating I need. This is for my 2018 Coachmen Freedom Express 25SE. I looked through all the paper manuals I have and also went to the Coachmen website and looked through the manual they have on there for my trailer but didn't find any battery specs. Is there a way to confirm which battery is supposed to be in the trailer or do I just have to assume that the one the previous owners had in there when they sold it to us is right and buy something equivalent?
I typically assume its correct, and then put what I would like to have in it when replacing one. For example mine came with a 24 series battery that only had 47 amp hours (baby battery), so I upgraded to a 105 amp hour battery when replacing it, this did require me replacing the battery box too that it sits in, but it was pretty easy to do so, the box is just held in with a couple of self-tapping screws in the base of it (deep cycle flooded battery).
Considering that is a pretty good size trailer, I can't imagine it would have anything smaller than 105 amp hour on it, do you know what series it currently has installed, and is there one or two batteries?
It's only wired for one battery right now. I don't really think I need a second since we pretty much only camp (with the trailer) in full service sites and I'm pushing up against the payload capacity of my truck.
Here are the numbers on the battery that was in there. I guess that must say 80 amp hours?
Well 80 amp hour sounds decent, that is a lot larger than the one that came in my trailer so its probably the right size, especially if you are plugged into shore power most of the time, That's what I would replace it with if it were me. The only reason I upgraded is because on long trips I run our 12v fridge and we needed the extra power for dry camping without electricity, otherwise I would have stayed with the small one I had too.
The main reason for a battery besides being without plug in power, is to provide the working amps to run things. The convertors can run everything but when amp draw is large a good strong fully charged battery makes sure the current and voltage stay within correct ranges. Furnaces and slide motors are the real hogs. Most times it is the dealers that put the battery in and they cheap out on it to save a nickel. It would not hurt one bit to have more capacity, but can hurt to have to little. Having said all that, it depends on your potential loads and how it has worked for you with the current battery.
Agree and my rule of thumb for this is to use the battery of greatest capacity that will fit in the box. This might end up being 5-10lbs more but that is negligible compared to having sufficient power to run everything efficiently.
Good points. It's hard to say because I think this battery was probably weak when we bought the trailer. I'm not sure how well the previous owners took care of it. I noticed on our first trip that the converter was running for quite a long time after we finished getting set up. I'll talk to the folks at Battery World and see what they recommend.
If you could get a look at your convertor it is rated for x amount of amps. Most I have dealt with are 45 to 55 or 65 amps. Larger campers and motorhomes have larger ones I am sure. I would trust the original design not what the dealer put in. The battery box also came from the dealer so it does not indicate what is needed. Personally, I have a 26 ft TT with no slides and I have a 27 series battery rated at 122 amp/hrs. I also removed a 24 series and upgraded. You know that even the original design was right at the edge of what they could get away with so a little extra omph with the battery can't hurt.
No specs in my converter manual. I'll have to see if there's anything on the converter itself next time I'm at the trailer.
Simply replace the plastic battery box with the largest box that the battery store has that will fit the location of the box inside your RV - some measurements required. Then buy the largest amp-hour 12 volt battery possible that has the battery terminals of the style and arrangement that you need for your RV cables.
This took two trips to the battery store for me but it was worth it - I got a very large diesel truck 12 volt battery that I could adapt my travel trailer wiring to - new and different connections required for me. And now this battery is treated kindly all the time by being on a set of two Harbor Freight solar panels (of 4 from their kit) when my trailer is not in use.
And all four panels together are very helpful on even a cloudy day to keep this battery topped off when camping with no commercial power.
Rick
Rick
Psst! You can do better than Harbor Freight panels. There's used panels out there that offer as much as 300 watts of 12 volt power, and they're CHEAP, compared to new price for high-end panels.
Just sayin'.....Roger
Hello Roger,
Yea, I know . . . but my area here in Louisiana is not a mecca for the solar panel industry. I bought these HF panels and charge controller when I was a solar panel newbie and they work quite well for how much I paid.
Rick
That's a 90 amp hour battery according to Armada specs. I had never heard of them but they offer a pretty nice warranty - free replacement for 3 years and prorated for the next 3 years.
If you're worried about weight you could go with a LiFeP04 battery, assuming your converter/charger has a mode for charging those. They're MUCH lighter than lead acid batteries. For example, the 100 amp hour ones weigh 26 lbs. each. whereas the 100 AH lead acid batteries in my truck camper weigh about 70 lbs. each. These days they're much cheaper than they used to be, but they'll still cost you more than lead acid.
If you would rather keep trailer capacity stick with the 24 series. If you never camp off grid may I suggest a car cranking amp battery.
As stated above the battery is for high demand applications. If you will always be connected to shore power deep cycle is not needed and cranking amps are.
The advantage of this is lower weight and lower cost combined with superior demand power.
You will not find a battery chart for tts because you choose the application/service you need.
What he said^^^, but you have to be careful to not over discharge it as cranking amp batteries are damaged sooner then deep cycle batteries.
