Hello! I'm new to this forum and RVing in general. I'm currently looking to purchase a travel trailer, scheduled to pickup next Saturday. Since looking a couple weeks ago, I've been spending a lot of time focusing on the numbers to ensure I can safely tow.
Travel Trailer
Cherokee Wolf Pup 17JG
Dry Weight - 3,879 lbs
Dry Hitch Weight - 430 lbs
GVWR - 4,999 lbs
Payload Capacity - 1,120 lbs
Length - 23ft 4in
Tow Vehicle
2022 Dodge Durango GT Plus
Engine - 3.6L V6
Dry Weight - 5,060 lbs, recently weighed at CAT scale at 5,040 but made some adjustments for fuel and a couple other things I had in the vehicle at the time
GVWR - 6,500 lbs
Payload Capacity - 1,440 lbs (GVWR - Dry Weight)
Cargo Capacity per door placard - 1,200 lbs
Max Hitch Weight - 620 lbs
Max Tow Capacity - 6,200 lbs
GCWR - 11,600
Wheel Base - 119.8 inches
I'm feeling pretty good about the TV capability to tow this TT. I am purchasing a Sway Pro 750 Sway control/WDH. I am cognizant of the payload capacity of the TV. I'm aiming to put a max of 700 lbs of gear into the trailer, which will give a Hitch Weight of around 600 lbs. One of the things I'm most worried about at this point is the wheel base of the TV vs length of the TT. I'm also aware of the wind drag I'll be experiencing with this trailer vs a pop-up.
I live in the upper Midwest and don't have any plans at this point to be going into any mountainous areas with this setup.
Being new to the game here, is there anything I'm missing? Should I be re-considering a different trailer? Or am I OK thinking I'm within my limits and go have a good time?
Thanks!
