Most of that depends on how you drive and care for your vehicle. Get a vehicle suitable for the task and keep the maintenance up, drive sensibly and you should get good service from any of the brands.Wanting to get travel trailer what is most reliable half ton for towing will match trailer to truck
Consensus among most reasonable halfton owners is that you should be able to go up to a ~25 ft travel trailer and still be within the capability of your truck (obviously depending on the specific truck and trailer and how much gear you have).Gary, knowing what I know now, I wouldn't even consider a 1/2 ton for the purpose, unless you're going with a small fold-down or short hardside camper. Getting a 1/2 ton with travel trailer towing in mind is really going to limit you on trailer choices to fit the load capability of the 1/2 ton.
(Sidebar); My definition of a "camper" is a fold down, or hardside of no more than 14 ft. to 16 ft. in length. A "travel trailer" starts at 16 ft. and gets longer and heavier from there. (Although you might be hard pressed to find a 16 or 18 ft. "travel trailer" nowadays.)
My '04 F150, (with factory tow package) has a 7050 GVWR, and it was a bear to find a 5er light enough to stay at least marginally within the weight specs.
Start with a 3/4 ton, and your choices for "living" quarters will vastly improve.
Roger
You don't listen to Tim the tool time Taylor.Consensus among most reasonable halfton owners is that you should be able to go up to a ~25 ft travel trailer and still be within the capability of your truck (obviously depending on the specific truck and trailer and how much gear you have).
I prefer the Ram trucks. Great running and the interior is 2nd to none. I towed 7500# loaded for many years with the half ton-no problems. I moved up to the 3/4 ton Ram when I purchased a heavier trailer.I've been towing with a half-ton for 13 years with two different travel trailers. One had an empty weight of 3,400lbs. The other, I currently use, has an empty weight of 4,800lbs. Fully loaded with water and cargo it weighs 5,400lbs.
I tow with a 2010 Toyota Tundra with a tow rating of 11,300lbs. As others have mentioned, everybody has an opinion. My personal preference is to cut 50 percent off whatever the vehicle manufacturer says I can tow and use that number as my guide.
I've never had a problem in the 13 years I've owned my truck. I attribute it to good maintenance and having a lot less wear and tear.
hope this helps!
Not sure he would meet the definition of "reasonable".You don't listen to Tim the tool time Taylor.
Glad you got it! I once went to a campground that had a 24ft camper limit, I went with a 32 ft MH. I fit but 24 would have been better!Not sure he would meet the definition of "reasonable".![]()
Don't mis-understand.......I'm not saying a 1/2 ton won't do the job. Shoot, I pulled a 24' Jayco travel trailer from Iowa to Arizona and back without incident. The following year, it went up into Michigan, again without incident.Consensus among most reasonable halfton owners is that you should be able to go up to a ~25 ft travel trailer and still be within the capability of your truck (obviously depending on the specific truck and trailer and how much gear you have).
