2022 Bay Star Sport 2813
sharon1199
Hello:
Traded in our 2016, 40ft 5th wheel (Jayco Pinnacle) for a 2022 Bay Star Sport 2813. Have had a lot of issues driving it home from NC to Illinois. It has only 3900 miles. Have a couple of questions. I have read a lot of info on how to improve the ride (to get rid of the "death grip"), the fishtail effect and the pushing effect broadside when the semis fly by. After much research - I'm upgrading the shocks to Koni on the front, Sumo Springs on the front and rear, Trac Bar for the rear end and Safe T or Roadside steering stabilizers. Hopefully this will improve steering, get rid of the fishtail and get rid of the "floating down the road" feeling. Any input would be appreciated. Our toad will be a 2006 Jeep Liberty diesel. Thank you.
Install Koni shocks on the rear as well. They help significantly with the damping, up/down movement of the coach!
Also, get your coach weighed, so that you have all 4 corner weights. Once you have that information, look at your load distribution, especially front to rear. And also utilize the tire pressure charts for the "correct", not maximum, tire pressures, which will improve the ride!
And if you want the ultimate ride/handling, you could do as I did, & install "Liquid Spring" four corner suspension!
About $25K, but rides, drives, & handles like a big SUV!! Fantastic!!
Good Luck, enjoy your coach, and may you have many Happy Smiles & Miles!!:cool:
You can do all that at once and be a little happier for a lot of money, or do the susension mods one at a time and stop spending when it rides and handles better.
Remember that this is a commercial truck/school bus chassis. It will always ride like a school bus.
Personally, having spent a little time behind the wheeel of a bus, I don't complain too much about the way my 34ft rides. I did do the CHF on the rear and that improved the handling much more than I anticipated. It cost me about an hour of my time...
I'm debating Sumo Springs or Sway bar links for the front at this time.
The best thing to do is get more seat time and get used to driving a bus.
Hello:
Hi Sharon1199, we have a 2019 BSS with just over 7,000 miles. It replaced a 2018 BSS that got totaled in February. This gave me a great comparison: Our 2019 has Koni shocks all around, the Safe T Plus steering stabilizer, and supplemental 1 3/4" rear anti-sway bar. Compared to the stock 2018 model, these parts make a HUGE difference versus what you experienced. In fact, I bought it used in Oregon and immediately drove it all the way home to Arkansas. What a difference!
However, I'm taking another couple steps: replacing the stock FRONT anti-roll bar with a Roadmaster 1 3/4" unit, and adding a rear Roadmaster track bar. I believe these two items (and maybe radius arms) will all but eliminate excess roll and tailwagging. At the very least consider the rear roll bar, Safe T Plus, and the Koni shocks. These were all installed at Henderson's in Oregon.
Good luck!
I would suggest contacting Hendersons. I did one of there kits on by buddies Bay Star and it made it so much better to drive and handle. Installed track bar, koni shocks all around. Radius arms. Bigger sway bar in front. Added a sway bar to the rear.
You can reach Henderson's at: Henderson's Line-Up, 1-888-898-3281 or 541-479-2882. They are in beautiful Grants Pass, Oregon. It might be worth the drive from Illinois! They are that good at getting you the motorhome you want.
Get a front end alignment as well.
Welcome to the group.
Welcome.
I've not done any of the chassis modifications to my 2023 and am quite comfortable with how it drives and handles. Indeed it's not a 40' diesel pusher, but it is certainly controllable and has performed well for us so far.
These mods were made to a Canyon Star but should work for a BayStar, same F53 chassis. This RV handled better than most RVs, including DPs.
We installed the Liquid Spring on the rear prior to it being available at all four corners. We would have opted for the four corner system rather than just the rear.
We had it installed in the rear of our E450 chassis Forester.
It is an amazing system and was like driving a whole different vehicle after that.
