slide out
  1. B
    Forest River ROCKWOOD ROO Slide Issue
    I have a 2018 Forest River ROCKWOOD ROO 24WS and recently the interior wall bows out when I pull the large slide in the whole way - see attached pic. Has anyone had this happen to them and what is the fix? Thanks
  2. S
    Question 2007 Allegro Bus QSP Slide
    In the past I've had a 2004 Bus and a 2005 Open Road, and a few 5th wheels. Now I'm looking at purchasing a 2007 QSP on the Spartan chassis. The curb side bedroom slide has what appears to be a scissors mechanism in the wall instead of a lower slide. When the slide is open there is about a 3"...
  3. R
    Jamboree Slide out
    I have a Class C 2006 26 foot Fleetwood Jamboree with a single slide. I am trying to figure out how to access the slide motor. I want to be able to manually retract the slide in case of motor or gear failure. I have looked high and low to find the access. I found a small opening, 6”x6”, on the...
  4. H
    Question Slide trouble
    Hey everyone. We have a 2013 323tbr and I had been working on the floor in the main slide. Git the floor done and went to close it up and it moved about an inch before it stopped. Now it will not go either direction, only making a load clicking noise. Any ideas what's going on with it?
  5. C
    Slide out not working normally
    Simplest way to explain it, is slide out won't work normally. But seems to have power. Steps I've done: #1. Replaced old battery w/ new. #2. Tested wires going to the 40amp short stop breaker as well as the 30amp short stop breaker. (Seems to be working fine 12v the whole way) #4. I have...
  6. S
    Question Manual Slide out (screw drive) seems stripped
    Good afternoon! I have a 1999 Fleetwood Prowler 825Y travel trailer with a manual slide out. Last weekend, while opening the slide-out, I felt the crank give (almost feels stripped) when it was about 5 inches out. I was able to crank the other way and fully close and secure the slide-out with no...
  7. D
    02 jay manual slide doesn't work
    I recently acquired a 2002 31 by jay flight from my cousin with a manual slide. He had stated the the slide was stuck out, I was able to make it retract, however it seems like the hand crank lever isn't engaging the the gears for the slide. I've owned a lot of campers , but never a manual crank...
