water heater
  1. U
    Lighting pilot light for hot water heater
    Hi Fellow RVer’s, It seems as if my pilot light from my hot water heater went out and I’m trying to figure out how to get it going. Any help? I can’t find any videos on it for my rig.
  2. H
    Atwood hot water heater discharges water from the pressure valve
    I've got a 2008 HR Endeavor with an Atwood gas/electric hot water heater. When the unit is first turned on it discharges water from the pressure valve for a while. I capture the water in a container but it is a bit of a nuisance having to empty it every day. I've changed the 2 sensors in the...
  3. J
    Water heater leaking while winterizing?
    Hello, I've got a 2018 Kodiak Cub 175BH that I am winterizing for the first time. I was following the process as shown in this YouTube video, switched the heater tank bypass valve and I left the hot water tank plug out. I began to pump anti-freeze through the water lines inside, and when I went...
  4. M
    Water heater question.
    Howdy. Has anybody ever installed a tankless water heater, into a travel trailer. By tankless i mean like the ones you get at HomeDepot or Lowes which are normally used on houses, they are instant hot water. My 6 gallon electric and gas water heater just went out and I am curious to see if i...
  5. B
    Tankless water heater
    Hello RVer’s. I am new to the forum. I have a 2014 Evergreen Sunvalley. I am having trouble keeping my Atwood OD-5001 tankless water heater lit. I was just gonna replace it as the date on it is June 2013. I contacted Dometic/Atwood to see what I could replace it with without having to make...
  6. B
    Question Anyone Know of a Good Quality Electric Water Heater?
    I always stay at places with full electric hookups and spend most of the cold months plugged into my grandfather's house in WV, so it would be more cost-efficient for me to switch to an electric setup to save on propane costs. Currently, I have a 6 gal Atwood G6A-8E propane water heater, but...
  7. R
    Resolved No hot and cold water to kitchen sink, no hot water to bathroom sink and tub?
    This morning I discovered that I have no hot and cold water flowing from the kitchen sink, and no hot water coming flowing from the bathroom sink and tub. It was about maybe 1 degree fahrenheit last night. I realized I should have insulated to cold and hot low water points that hang down from...
  8. Neal
    How To Verify your ITR OASIS Two Electric Burners are working
    In my other thread about AC Heat not working I had a short, a second electrical short in the wiring of my OASIS system. In verifying the wiring ITR Heat had me go to my EMS panel and then turn AC I on and check for an AMP change. I showed +12 AMPS. Then switch to AC I and II and you should see a...
  9. Akdare
    Atwood Gas/Electric Water Heater 2019-11-16
