2016 Coleman Lantern 17BH Literature
dnrhood06
I'm trying to do a little research on my Coleman TT to replace/upgrade some electrical items. The converter doesn't work and hasn't since we bought it 2nd hand around 2 years ago. I also notice that the electrical outlets do not hold much of a load at all. We brought an air fryer with us a couple of times because it is easy to cook some items with it and we also brought a small electric griddle for pancakes and other things. Those two things can't be ran at the same time or it will trip the breaker. We have ran used them on a GFI outlet and either the external outlet or another internal outlet and it still blows the same breaker. I have one 20 amp breaker labeled General Purpose and the rest are 15 amp.
Could I just replace them all with a 20 amp since the wiring is the same as home wiring? It doesn't seem like those 2 things should trip the breaker. Also, where can I find documentation on the wiring? So far, Google hasn't found much. The Dutchmen site is all that comes up and I can't find a Coleman Lantern on it.
I really want to upgrade the converter also to something a little better with the ability to switch the battery to a Lithium. What would be better to replace it with? The type that came in it, or a Progressive Dynamic (or any other brand? I really need to find a wiring diagram to help with this though so I can understand how it is wired.
What is wire size on all circuits? The 15 amp.is probably #14 wire only 15amps. The 20amp is probably #12wire
20amps. Be very careful installing bigger breakers than original size. Is the wire in the walls loose if so you could install bigger wire. Just talk, I aaaam retired now but started eledc. work in 1957. Good luck.
