Jim
- Dec 18, 2019
- North Carolina
- Essex 4543
- Spartan
- Cummins / I6 Diesel Pusher 605HP
- 2016 Jeep Rubicon
This is normal on FL and should be ignored.Thinking about it I repalced my chassis batteries at 6 years also even though they were working just fine. The only concern was that my LBCU read “Low Battery” every time I turned on the ignition, but it does that with the new ones too and I came to the conclusion that it is reading charging system voltage and only sees battery voltage when the engine isn't running.
This is whaI get with 6 210+ agms only two years old. I need auto gen start.Kevin, here's my best answer to your question(s): Last night I removed all the load I could at about 10:30. The Silverleaf display showed the status at 14.4. I slept and six hours later it was 11.1. At that point I started the generator and ran it until 4pm (11.5 hours). During the first hour, I checked the display and it showed 14.4. While checking in to the new campground, getting parked and set up, about 30 minutes, the display dropped to 12.1, when I turned on the 50-amp shore power. 15 minutes later it was at 14.4 again. I'm thinking I've convinced myself that these batteries are on their deathbed.
