2021 New mar New Air, dash air conditioner not working. Blowing warm. I have lots of Freon in the system according to the gauge I hooked up. Pulled fuse and replaced , not sure what else to do.
Brought coach out of storage finally for next trip after 8 months and I don't think the dash A/C is blowing cold air. Recirc etc. Any suggestions in anything I can check? Fuse bay shows all good. 6 years and fine until now. Next Gaffney visit is November.
Gdoubleoo - does the compressor clutch engage when you switch the ac on (even for just a second)?
Theere was a known issue the Eaton PDM (Power Distribution Module - many fuses and breakers) next to the chassis batteries 2019-2021 and Freightliner has replaced them under a recall.
Also- i had the actuator at the heat/ac transfer box in the front go bad, so it was always circulating hot engine coolant and the AC cannot overcome the heat.
(PDM can be done at any Freightliner Elite service dealer after they get parts. Takes under a day. The coolant circulation i bypassed on the road and then replaced the servo/valve. Its a really archaic design….
