Problem 2022 Dutch Star High Tire Temperature
tlyon262
I have a new 2022 Newmar Dutch Star 4369. First trip abandoned after experiencing TPMS warnings of 178 and 180 for the inside rear tires. I checked the forums, which suggested faulty readings on the TPMS, but the smell of burning rubber has me thinking the TPMS was accurate. I am stunned the TPMS does not have logs or history to be pulled. The issue/warning must have come up when delivered from Newmar to the dealer here in California. Now the adventure of getting to a Spartan repair facility. If anyone has had the same issue and can offer information helpful to the Spartan tech, I would appreciate that.
Sorry to hear of the saga. I've heard of things like this on New Aire's. You can verify temps with an IR temp gun.
https://www.amazon.com/dp/B00DMI632G/?tag=rvf01-20
Sounds like you may have a brake or bearing issue is my guess. Did this just start happening? It is happening consistently or a one time situation?
What tire pressures are you running?
It happened on the first time using the RV. As I recall the dealer set the tires at 100 in front and 90 in the rear. The RV had 1,500 miles from the delivery from Newmar to California. That was why I asked the dealer if they could pull a log or history from the TPMS. I was told it does not have that function. Seems silly not to have that as a basic function. I will call the Spartan center where I have an appointment and ensure they will include checking the brakes in the scope of work. So far they want to focus on weight between the rear and tag axle and put nitrogen in the tires. I took a pic of the warning. Temps stayed high on those inside tire so I parked the rig.
I assume you have the same TPMS (Valor) as is on my Freightliner. It has issues. False temp readings, false psi readings, and basically punting any semblance of reliability into the stands. Supposedly there is a fix that requires tweaking the receiver antenna. Freightliner has a recall on it, not sure about Spartan.
I would not pass go nor collect $200 without first verifying the veracity of those temp readings with a IR Thermometer as @Neal suggested. I’ll bet @Neal’s money that is false information.
Great suggestion. I will purchase a temp gun and see what temperatures are happening. I also have an appointment at a Spartan repair facility next week. Covering all the bases. It is 100 mile drive to the repair center so I can measure at 50 and 100 miles. Appreciate the help.
I agree with Neemer and have no experience with OE TPMS but that display looks like its indicating too much braking on that axle to me.
OEM TPMS is useless. I ignore it and have TST TPMS that I use. I am pretty sure the antenna issue was addressed by Spartan previously.
Sounds like you have a plan which will get it addressed. I would see about getting the coached weighted it sounds like your rear tires maybe over inflated, most are running 85psi in the drive and tag based on Michelin chart. I have seen high pressure warning on the back tires but never over 106psi. High pressure warning is a % of what the set point programmed in the system, which Spartan can adjust.
I appreciate the input. I called the Spartan facility and they added a day to the work order. They said the work order will include weighing the coach, weight distribution between the main and tag, tire pressure, and a break inspection. The coach goes in Thursday of next week.
On the antenna issue, that seem suspect to me. I spent my career in charge of service for a technology company and I have the scars of supporting equipment that did not exactly do as the manufacturer stated. We dealt with wireless access points from the early days as they matured into amazing technology. Typically an antenna issue will result in a loss of data versus erroneous data. Valor seems to not want to share any information or respond. One constant was the customer seems to always be the best source of data so I will assumed the system is faulty.
Those same set of tires increase in pressure and temperature on my coach when I'm towing something close to the tow limit.
Not sure if I have all my tow setting tuned perfect to prevent the heating, but that's just my observation.
Are you towing?
I am towing a 2022 Jeep Cherokee Trailhawk, 5,500 LBS. Has the Air Force One brake system. The RV, car, air force one, are new so everything is a suspect.
I would not write off the TPMS system as just not working. It is reading the information the sensors are sending. I'm no expert, but my thinking is there is sometime wrong on that drive axle, dragging brake, bearing, low fluid, etc. You have drum brakes on the drive axle, have you preformed a per-trip automatic brake slick adjustment?
Contrary to what others have experienced, my Valor TPMS works as designed once I got the base pressures set. The only time I get high pressure alarms is when I leave VA in 40 degree temps and get to FL in 90 temps. I've never seen a high temp alarm. Per Michelin, the max tire temp is 194 degrees and operating above 230 degrees impacts rubber properties.
…and because it is only reading high on the inside duals, it really seems like it‘s indicating high heat there that is caused by some factor other than tires or the TPMS.
I'm not a fan of the Valor TPMS either but was lead to believe it was set up for use in Spartan Chassis. I don't think it's related to a faulty reading. Hopefully I'm wrong but IMHO you have some serious issues going on. Please keep us updated?
I want to offer thanks for all the input. The saga continues. I had the Dutch Star at a Spartan Authorized facility for two days. They did the weight verification, checked the brakes, and inspected the tires. They consulted with the Spartan rep and performed tests Spartan requested. All checked out fine. They set the front pressure to 115 and the rears at 85. The drive from the Spartan facility to my storage building is 70 miles flat driving on the I10. There was very light traffic and virtually no braking. Just cruising at 55 and a tail wind for the last 40 miles. I get 7.5 MPG with a tow car. I assume that is normal. I towed my Jeep Cherokee Trailhawk with the Bue Ox tow bar and the Air Force One brake system. Within 20 miles of leaving the Spartan facility I got the same high temperature readings on the inside rear axle tires and within ten more minutes the driver's side front tire and drivers side tag axle got high temperature warnings. The high temperature alarm stayed on for the remaining 50 miles. While the tire temperature showed alarms the tire PSI readings were around 130 in front and 100 in the rear which I am told is normal. I reached back to the dealer to see what they and Newmar now recommend.
I wrote to Newmar and expressed that I am baffled they do not take advantage of the miles driven in delivery to the dealer. Newmar can easily require the logs from the engine computer and TPMS be pulled. A simple basic quality assurance step. They can then fix these issues before the customer takes delivery. In my case there was 1,500 miles driven from Newmar to the dealer. Newmar did not respond to me. My wife and I have yet to use the RV other than the shake down trip and taking it to the Spartan repair. We have yet to name the RV. She rode along for the trips. While I listened to that audible TPMS alert she came up with and suggested less than flattering but funny names. Some were really funny and equally inappropriate. Hopefully this gets fixed and we don't use one of those names. Gotta laugh !! Thanks Again.
Curious about the name suggestions - maybe not suitable for all audiences? Hot Wheels immediately came to mind…
But onward, did you ever verify the readings with a hand-held temp gun? This should tell you where the problem is and either set your mind at ease, or give you reason to head back to the shop.
Maybe you have a bad set of drums that are out of round, so even if the brakes are in spec they are still over heating. Or maybe the temp function on the TPMS is just wonky. But either way, as is often the case, your efforts might end up being more meaningful than the shops, not to mention Newmar’s blind eye to the issue.
Can you disable the audible alarm? Your mpg sounds normal, and your suggestion to Newmar about using the delivery miles to gather useful info is a good one. I’m surprised they ignored you but maybe thats a WBGO thing, or maybe they like the idea but don’t want to admit anything.
Also about this: buy an after-market TPMS such as EEZ tire and install it and compare results. If you get the same readings (of very close) you know the chassis has a problem. If not its the on-board TPMS. At this point it seems worth the investment and either way, you could shove the results in front of the warranty folk’s noses. You could just use a six sensor kit to make the determination.
This is what I use: https://eezrvproducts.com/
