2024 DS 4369 Color Correction and Ceramic Coating
I guess its the luck of the draw with a Newmar OR an Entegra. Here is another's experience with an Entegra Cornerstone
1. Main door wind noise while driving. - Worked on by Entegra Nov 22 - Not Foxed
2. Wine Fridge needs a lock. Using Velcro for now.
3. Window above wine fridge shade is not aligned over the window. Just realized that after a year of ownership.
4. Back Bathroom left 2nd drawer down is crooked.\ ✅ Fixed by Entegra at super show.
5. Front passenger seat will not rotate unlock. Fixed by Entegra at super show but need a C clamp on cable.
6. TMPS Valor not working on outer dual tires. ✅ Fixed by Spartan by adding antennas. Nov 22.
7. Aqua hot exhaust to low. ✅ Fixed by Entegra Nov 22.
8. HVAC 2 not cooling enough. ✅ Replaced by Entegra Nov 22.
9. Washing Machine - Not running properly. ✅ Control board changed by Entegra Nov 22.
10. Bedroom Fan makes noise after turned off while stopping. ✅ Fixed by Entegra Nov 22.
11. HVAC vent leaking from passenger side kitchen return. When we move the coach after running the HVAC. I cleaned out the tube. ✅ Fixed by Hal Sep 22.
12. Aqua Hot electric not working. (Trips breaker high limit in aqua hot). ✅. High limit replaced by Entegra Nov 22.
13. Passenger side basement panel door catches on cooler panel door. ✅. Adjusted by Entegra Nov 22.
14. Front window behind couch is loose and leaks air when traveling . ✅ Fixed by Entegra Nov 22.
15. Grout cracks in floor in front of kitchen pull out. And at bedroom entrance ✅ Fixed Entegra Nov 22.
16. Bathroom rear mirror - separating from door. ✅ Fixed by Entegra Nov 22.
17. Shower floor painted and paint came off. ✅. Shower floor replaced by Entegra Nov 22.
18. Passenger seat stains and liner missing ✅ Seat replaced by Entegra Nov 22
19. Double door - Scratching and not sliding properly. ✅ Door replaced by Entegra Nov 22.
20. Wine fridge mounted crooked. ✅ Fixed by Entegra Nov 22.
21. Cracked tile in front of wine fridge. ✅ Fixed by Entegra Nov 22
22. Main Door flap rubbery torn near door handle ✅ Fixed by Entegra Nov 22.
23. Passenger chair arm (left) does not go up and down properly. ✅. Fixed new chair - Entegra Nov 22.
24. Coach body next to door step not bolted. Fixed at homecoming but is loose again. ✅ Fixed by Entegra second time - Nov 22
25. Tank sensors incorrect - All three tanks. Recall ✅ Fixed by Entegra Nov 22
26. Kitchen counter pullout hangs low after being pulled out. ✅ Fixed by Entegra Nov 22
27. Kitchen garbage door does not stay closed when traveling. ✅ Fixed by Entegra Nov 22
28. Closet light not working. ✅ Wiring fixed by Entegra Nov 22
29. Drivers seat does not adjust. (Fixed by Hal) - shorted wire was tripping breaker. ✅. (1 Aug 22)
30. 2 Tire pressure sensor not reporting (Spartan) ✅. Fixed at Spartan by adding two antennas. (3 Nov 22)
31. Chassis Batteries Weak. ✅. Replaced under warranty by Spartan (3 Nov 22)
32. Valid Air level null is off. ✅. Reset by Hal (1 Aug 22)
33. Condensation in docking light ✅ Fixed At Entegra homecoming - June 22
34. Oil leak. - Cummins ✅ - In Grand Rapids. March 22.
35. Left side mirror on medicine cabinet separating from door ✅. Fixed by NIRVC Feb 22
36. Router - Will not connect to the internet. ✅. Fixed by Hal Feb 22
37. Double door - pulls out from the wall ✅ Fixed NIRVC Feb 22
38. Rear bath - two white drawers crooked.✅ Fixed NIRVC Feb 22
39. Rear Bathroom door - does not close properly ✅. Fixed by NIRVC Feb 22
40. Main TV is not level ✅ Fixed NIRVC Feb 22
41. Front and floor aqua hot heat not working ✅ Aquahot Pump bad, Fixed by NIRVC Feb 22
42. Door to closet tightened ✅ Fixed by NIRVC Feb 22
43. Bathroom vent catch ✅ Fixed by NIRVC Feb 22
44. Drivers heat seat not working ✅ Fixed by NIRVC Feb 22
45. Vega touch does not see router ✅ Hal Feb 22
46. Wood kick plate under kitchen cabinet loose. ✅ fixed by NIRVC Feb 22
47. Generator not staying in when parked. ✅ Fixed by NIRVC Mar 22
48. Vega touch - Middle HVAC will not stay on cool only. Switches to auto. Also will not stay on heat only. Firefly. ✅. Firefly talked me through fix March 22.
49. Locking catch on macerator hose door fell off. Missing. ✅. Fixed by NIRVC Mar 22
50. Bed does not stay up. ✅. Wrong Struts. Fixed by NIRVC Feb 22.
51. Magnets on shower to hold better ✅. Fixed by NIRVC Feb 22
52. Def head / heat valve problem. Fixed by Spartan. ✅ Valve and DEF Head replaced by Spartan May 22.
Entegra also gives you 2 years or 24,000 miles to work the bugs out vs 12 months
One of the frustrating things I went through with Newmar is they used to let you make a service appointment for work many months after the 12 months just as long as the defect was noted prior to the 12 month warranty expiring. it could take 3 months lead time for an appointment. They now have a hard line of it must be repaired no latter than the 12 months and with special permission an extra 2 month extension . This is very tuff given the dead of winter is pretty tuff to travel back and forth to them for 3 months or so.
Getting back to factory pick up, I wonder if the buyer saves the $380 that Newmar charges for the temporary windshield protection that the consumer never sees. This used to be $80 not to long ago
I guess its the luck of the draw with a Newmar OR an Entegra. He is another's experience with an Entegra Cornerstone
Yes I have seen and read this list, and non are perfect
If they were exactly the same 24 months vs 12 months gives Entegra the advantage
Not my experience. As long as you provide pictures or report it, its covered. I have had wonderful experiences with two Newmar coaches and waiting on my third to be delivered. I prefer Newmar because the Entegra woodworking is sub par for the price point. When I looked at Entegra's at shows, there was always at least one cracked tile.
Point is to each his own. Many have some problems to be worked out. I doubt that Gus started this thread to be an attack on Newmar as you appear to be making it. He, in fact was happy that Newmar took care of his issue.
I believe the thread was about paint correction and to show off the beautiful ceramic coat he had done.
Best of luck to you with the Cornerstone! thats a great coach!!
Thank you, your DS is beautiful and I still love Newmar coaches, my issues are the management side of the company.
I see you have a 2024 on order, what Newmar did you have prior to that?
No not that I know of, they do have factory service.
NIRVC tracks defects at PDI and they have a pretty extensive process. The last numbers I heard was 13 defects avg on Entegra vs upwards of 50 items on Newmar. It is Brett Davis’s goal to start posting these numbers for all of the brands they represent on their website in an effort to keep the factories more accountable. I commend him for this.
This includes what is considered “Dealer” prep. Not sure what that entails but may be 4-8 hours of Prep work. Unfortunately it is the rare dealer that does any of the prep.
Remember this is a line built coach with many hands touching the assembly of various components. In a perfect environment it would be 100%. Using an assembly line the last 5% will double the assembly cost .
