Alex_KN0I
- Aug 21, 2023
- Devils Lake ND
- Fleetwood
- Flair
- 30'
- Chevrolet P25
- Chevrolet 454
I did search for this and had no luck finding anything...
Late last summer, I picked up a '91 30' Flair. It run spectacularly, Banks headers and exhaust, and transmission works perfectly. We took it on a couple of longer drives (3-4 hours each), and as time went on, I noticed that the brake warning light in the middle of the dash started illuminating more and more often. And, it seems to be based on engine speed. When the engine is idling, the lamp is off. As we start revving up, the lamp starts flickering and eventually will stay lit when the RPMs are up. When it upshifts, the lamp goes out momentarily, until the RPMs start climbing again. So, it seems to be related to engine vacuum.
The brake fluid level is normal, I don't seem to be losing any. The coach does pull to the right quite heavily initially on braking, but that seems to normalize after a few braking maneuvers but returns after a longer period of non-use, so I plan on going through all four corners in the spring. I also want to look at the parking brake, as it seems to not be working properly (and that seems to be a common issue on these chassis). But I just thought I'd throw this out to the group before starting on the work to see if there's anything else I should be checking on while working on the brakes.
Also looking for a source for the plastic exterior doors for the electrical and propane locations. REV doesn't seem to carry them. I've looked at 3 or four "local" RV dealers, and none of them have them. It'd be great if I didn't have to custom-make new doors...
Thanks in advance all!
Alex
Alex
