Question AC electrical
Old one
Altamonte Springs, Fl
Kevin: I know you can answer this.
On boats, the inpot power is (usually) a 30L5 or twist lock 30A.
On the pictures of RVs I see some of them, with a Clother Dryer type, "Y" plug forthe park end.Am I seeing this right?
The reason, I have a 50' 30 amp with 30L5s on both ends, andwent to make up input cables for home use for running battery chargers/maintainers, and fridge to allow set up the day before leaving, and A/C for while working on it. and possibly adapting my Honda 2000I.
That y plug has a different ground prong. This is a common problem with electricians hooking up campers to 30 amp 240v, not 30 amp 120v. You can make up a plug with twist lock but you cannot feed the 240 to the camper.
I have had at least 5 incidences where licensed electricians put 240 into a 120 camper. And other just look at the welding plug they have and assume it is the same. BUT, I will defer to the other Kevin as he is actually an electrician and has boat experience. Mine is just lobster boats and they dont plug into shore power.....lol.
A 30-L5 is a 115vac twist lock mostly available on generators for RVs?not so much. Your Honda 2000i has only 20 amp receptacles. A dryer Y receptacle has 3 blades for 220 vac without a common connection/wire.
An RV 30a receptacle has two angled blades one common and one line. And a post that is ground, and is designed for 115vac.
As for boats? The boat end of the cord is typically retained via a threaded collar. On one end the other end is not retained on shore so should the dock lines be worn through in bad weather. The cord has no way to be live should it be drug into the water. Nor will it pull the power post into the water. Boats typically smaller boats don't have 220vac connections ( a safety issue.)
I hope that answers your question. If not please clarify what you need an answer to.
Perhaps I sked thequestion wrong.
I want to make up "special" cables or adaptors, for plugging int the ouse supply while the RV/MH is in my yard for working on it, and stocking prior to a trip. Are the proper plugs and receptables available reasonably findable, such as thry Amazon, etc, at a easonable price. I am sure Ican find pin-outs on the web.
Yes, just make sure it is a 3 wire 120v plug. One hot wire, one neutral wire, and a ground. I have one at my house and the RV is plugged in right now.
Yes all but the RV cord cap is available at any hardware store. The RV cord cap can be found at RV stores or online.
I would look for a good price on an RV extension cord and replace the cord cap to match your house receptacle.
Avoid the dryer outlet because there will not be a common (no 115 combination available). The extension cable is color coded. The cord cap is color coded.
Brass screw is black/line 1, silver screw is common/ white, and green screw is ground.
I have a cord that plugs into my dryer outlet and the other end accepts my 50amp plug from my coach. I use it for the purpose mentioned above, to ready the coach for a trip.
Does your dryer cord have 4 pins/blades/wires? 50 amp service is not what the OP has. Using the ground as a return insulated conductor eliminates the ground.
In the 50's no ground systems were standard, today, and for many years the method has not only been legal, but is unsafe. Let's not confuse the OP with unsafe hacks. Please!
My setup is perfectly safe, it has been hashed over endlessly on another forum. My cord has the usual three prong dryer plug that goes in the dryer outlet for the house, the other end accepts the standard 50amp plug from my coach. My Power Watchdog has no problems with it.
The cord was custom made and came with my coach.
Far from what NEC would call legal or safe. NEC requires 3 conductors and a ground. I'm not saying it isn't a hack possibility, I'm saying electrical code says it won't meet minimum standards. Therefore it would never meet code requirements, ever, even when the cord was made.
P.S.
If you would like to connect with a forum that would have your back on this subject try this one.
