For the most part they are set and forget. A well sealed valve cap is the answer to longer times between service. If you start getting more pump cycles check the air pressure (with no water pressure).
I have used one for over 7 years without worries. What to expect!
Longer pump life.
Less pump cycling.
Better flow control at faucets, and shower.
I also have the benefit of higher RO filter output! When I am not using the boost pump.
