Resolved Air conditioner kaput (Dometic Penguin II 15K BTU A/C + Heat pump)
Make sure you discharge any capacitor before handling it. It can make you hurt yourself.
Discharged it 1200 times, also bought a discharge tool. I was unable to test mine with a multimeter. Just shows OL no matter what I do. I watched YT videos, either mine is truly dead or I can't figure out the fluke and it seems straight forward.
I wish I would have known to carry a spare one of these. How many people replaced complete air conditioner units instead of replacing this $80 part? If you don't have one, I suggest carrying a spare. I'm ordering two, one for spare.
Dometic 3314471.017 Capacitor
Well, I guess I should be thankful I got 9 years out of her. The front A/C is now coming on making a low pitch hum and then turning off. I have the Microair soft starts in both which I attribute to why I got this much time out of them but now it's time to figure out where to get this fixed and with what.
I have the Dometic units with heat pump as most of us with Newmar have. And per @Chuggs recent saga I think Dometic is out of the picture now or are they coming back into play? Do I get this replaced somewhere local in the Ashland, VA area or do I go to NIRVC, Newmar, or where would you suggest?
My trip actually comes to an end tomorrow so I'll rough it, one works (aft unit) and the temps will cool down in the evening and overnight so it's not the end of the world.
I welcome any suggestions as to what I'm hearing and what you suggest for getting a replacement. I think at 9 years I should probably get both replaced at the same time.
Thanks...
P.S. I don't know if I have 15k or 13.5k units.
i would try to find 18k btu for replacement.....I would suggest try swapping capacitor from your good working AC.....could be the only problem
the capacitor will be behind a aluminum shield. my 15k dometic is a 55/15 dual capacitor. looking forward to front of coach with cover off ...be on right side near control board
$80 is way to much for a capacitor. I wish I could get that for my remaining stock. You have to set the Fluke to the correct setting. It is not ohms. It looks like and arrow pointing to a vertical line, sometimes curved and a straight line come out of the point where the arrow touches or nearly touches. Batteries must good in the multimeter.
There were cheaper options half the price but this one had 92 5-stars so I’ll take it. Cheaper than replacing the AC.
I did use the right setting. I’ll try putting fresh batteries in the fluke.
Ok, You have to hold it on there for a bit to give it the chance to put a charge into it and read it. 5 or 10 seconds.
Thank you all that chimed in to help me with this issue. You saved me a ton of money and I didn't have to switch to Geico! I wish someone would have shared long ago a recommendation to carry a spare capacitor as it can save discomfort, trip cancellations, service visits and a ton of money that is simply unnecessary. As mentioned before, I wonder how many people got suckered into changing out their A/C unit instead of just replacing this simple part?
If you don't have a spare capacitor, order it now! If you have a unit other than a Dometic Penguin II I suggest figure out what capacitor is in yours and order one for a spare. In my coach, the front A/C is critical and while mine luckily failed one day prior to the end of trip, it was uncomfortable. Had I had one of these and known about this, my discomfort would have lasted all of one hour! It is plug and play and could not be simpler.
Click here to order a Dometic Penguin II capacitor. I now carry a spare!
Yes, there are cheaper versions of the same I bought but I wasn't going past the 92 5-star reviews to find something that may not be as trusted. I wanted a known good and be done with it.
They are not the same, mine is a dual run capacitor for A/C and Heat Pump. I'm not actually sure what the differences are, other experts here can help with that.
I have no problem spending what I did compared to what I was about to spend! :)
