Air Horn
DKRITTER
Haslet TX
Dutch Star 4318
Cummins 450hp
2022 Ford F250 4X4
We have a 2013 DS. We were leaving a friends house in Colorado where we had been for a couple of weeks yesterday morning. I tapped the horn button on the steering wheel as we left and the air horns did not work. My initial response was why did she turn them off, but they were switched on. Regular car horns work fine.
As we drove when able I'd play with the horn and the switch still no horn.
Where do I start looking for fuses or relays? or what
I would start by using a voltmeter. Disconnect the terminal spade, and measure voltage to ground witj a helper pressing the horn. This would be a decision point... IF Voltage = Yes THEN Air Problem, ELSE electric/switch problem.
Fuse I woukd guess is in a panel under the driver basement compartment...at least that's where I would start. But it could be a loose wire, or bad switch contact.
