air module on 2007 Dynasty
jones@thecoast
Just bought 2007 Dynasty with air only leveling system. Front air gauge cycles but does not show air pressure. Air leveling system works but cannot find level. Air compressor comes on about 5 minutes after bus engine is cut off and runs continuously until engine battery switch is turned off.
Has anyone experienced this situation? Any suggestions as to how to fix it?
thanks. aj
My 2004 Dynasty has the air leveling module in the pass thru basement compartment with the slider. Its mounted to the ceiling and has a small compartment door for access. Sounds like you have an external air leak.
Congrats on you purchase. As Tommyson mentioned, you likely have an air leak. In fact, you probably have multiple leaks. This is normal. Easy to track down and repair if you are able and have some mechanical ability.
What leveling system do you have? If HWH are you pushing the level button twice to level? Paul Maddox is a HWH Tech and is always willing to try to help folks out. His email is [email protected]
