Problem Air slowly leaking out of the front system
Jumbo c
Noticed a slight leaking down on the front system on my 2008 Spartan Kountry star. Will be troubleshooting this week but want to ask if any one knows of a known place to check first thanks Jim
This assumes you have air ride. I would start by spraying soapy water on the ride height valves near each front wheel. Your air tanks should be between the frame rails between the front wheels and there should be moisture ejectors on each - spray them too.
Moisture ejector:
Leaky moisture ejector:
Ride Height valve (many variations/brands):
Leaky ride height valve:
Found it but what is it. Lol
I don't know but I would call Spartan and send the pics if necessary. I bought the replacement moisture ejectors and ride height valves from them.
Happened across this Spartan air system diagram from 2001. The solenoid valve looks to be closest to what is in picture of question. Also, you can reach out to Parts & Accessories - Spartan RV Chassis
Ordered new valve master dump #2538-MM5-001 called Spartan and confirmed part used on chassis build. Should be here Thursday. Will update. Thanks for all the help
