Question Any idea where the power inverter is?
91CavGT
Just Idling Around
South Texas
Coachman
Chaparral 360IBL
2018 KIA Niro
Yes
I’ve got a 2021 Chaparral 360IBL and I’m looking at doing some electrical upgrades to it. I checked all around in the basement, took panels off and checked around the furnace as well as the water heater and see nothing. Opened the front bay door where the battery is at and there’s nothing in there either. The power wires from the battery go to 4 circuit breakers, then go down into the enclosed underbelly.
I’m planning on replacing the battery that came with the RV for lithium batteries. Haven’t decided which one yet but have narrowed the options down quit a bit. The solar connection on the outside of the RV leads to a hefty set of 10 gauge wires so I’ll be connecting a beefy solar charge controller that I’ve already got to that. From the factory there was no charge controller which was surprising. Eventually I’d like to replace the inverter with a larger one to take advantage of the more powerful batteries, but I can’t do that if I can’t find it!
Joe Goodxrvn
Florida
CanyonStar
39' 11"
Demco KarKaddy 460SS and VW Passat
You might check the user manual. Does the model you have come with an inverter?
91CavGT
Just Idling Around
South Texas
Coachman
Chaparral 360IBL
2018 KIA Niro
Yes
I opened up the zipper pouch that came with the RV. Luckily I found the model and serial number list of all the devices in the RV. On this list, there is not a power inverter listed.
So I kept looking around and researching. I did find a circuit breaker in the breaker/fuse panel that is labeled “generator”. It is going to take some digging around to find where these wires are, IF they were ran, to the front storage area. A power inverter could be connected to this 15 amp circuit, maybe.
I’ll be looking into this more after I get the lithium battery bank installed and will go from there. Thanks!
