I had mine replaced in my 2015 London Aire.
Freshjet 5 replaced the Penguin 2, 15k BTU and Heatpump. It is plug and play provided you get a freshjet 5 with a 1.5 firmware version and 2 of the rj11 adapters.
The control board/box firmware needs to be version 1.5 or greater to work with the silverleaf. You can't update it, has to be replaced. For me it was easy with a 3 way call with my service tech and Dometic. Other people have gotten then run around getting the box replaced under warranty. YMMV.
There's a newgle article on it now as well.
https://newgle.newmarcorp.com/s/article/How-to-Remove-and-Replace-a-Dometic-Roof-Air-Conditioner )
“Dometic Penguin II roof air conditioners have been discontinued. If replacing one, use a Dometic Fresh Jet 5 with version 1.5.0 or higher, as the wiring and plenum layout matches for an easy installation. You need an adapter (RJ11 to RJ45) cable to plug in the existing communication cable (Newmar part # 039192). If the air conditioner you are replacing has two communication cables plugged into the existing control board, you will need two of the adapters.
Always set dip switches correctly to match the dip switch setting of the A/C you are replacing.
If this is on a coach equipped with a SilverLeaf system, the TM-510 module will need to be viewed in the SilverLeaf component list. If the version has a D after the numbers (EX: TM510-1.25D), it will need to be replaced with a version that does not have the letter D after the number. The versions without the D after are 5V versions; the versions with the letter D are 3.3v versions will not work with the Fresh Jet 5. If it is a 3.3v, you will need to replace it with a 5v version (Newmar part #039864)."
The unit I got was FJX5557EHPWHCS and it came with 1.0, dometic replaced it with a 1.5 box overnight ( for free under warranty ), but there was also local board with the version available as well through an authorized dealer.
Install, match dip switches and power down AC and 12v ( fully reboot silverleaf so it autodetects ) and it came right up and worked just as the penguin 2 did before.
Also when we did mine, the wiring looked different, but we just needed to pull the harness out of the ceiling more and the right connectors were there, Newmar just wired some extra wires on with wire nuts.
I posted more over on irv2,
Dometic FreshJet 5 with Silverleaf multiplex system One of the silverleaf/trillium guys is on there. Mark O and Art are who you want to talk to if you call them.
