Any water intrusion or damage
Kevin Lumney
We’re thinking about buying a new (2027) Intech Sol Dusk. We just toured the factory, and the build process and business model they use at Intech sure look great. However, it does appear they use a wood floor. Yes it’s covered by that tight weave material on the inside and a black membrane sort of material on the outside, that frankly looks pretty flimsy. Has anyone experienced any water-related issues with the floor. I’m mostly concerned about intrusion to the wood from the outside. Thanks in advance for any insights.
I can offer you comments on the black material, since it is also present on the underside of our 2019 Intech Flyer Explore. Our Flyer Explore, not having the current production "extended brow" over the ramp door, experienced a long term ramp door leak along the upper edge of the rubber seal on the right hand side, due to my not keeping an eye on the pressure pads at the ramp door lever locks as they gradually compressed over time, lessening the closing force on the door seal. No fault of the Intech ramp door design.
The damaged floor became apparent when additional tie point holes were being drilled thru the wood floor under the rubber “coin” material on top. It was necessary to cut into the black underside poly material to let out water that had saturated the wood floor in the right rear corner of the Flyer Explore toy hauler due to the door seal leak.
The black material on the underside is configured very similarly to corrugated cardboard, as two skins with a wavy core, but made entirely of a poly material. It has similar longitudinal stiffness to cardboard, with only minor sagging visible in spots under our seven year old Flyer Explore, and in only one direction. Our 2026 OVR Navigate has that same material underneath its floor.
I am confident that no water intrusion from road spray or puddle splashing is even remotely possible with the poly corrugated underside material in place under these trailers. For our Explore, we made some small punctures in the poly material in order to check firmness of the nearby remainder of the floor past where the damage had made the wood saturated with water and soft when poked or drilled thru. It was not necessary to replace the small area of soft floor at the present time in our usage case. (We did add a 1x3x1/16" aluminum rectangle tube member, on brackets, under the soft section and used that to anchor the new tie point to.)
The 2026 OVR Navigate has a woven floor material as the walking surface. Presumably, any water spilled on the floor can dry out thru the open weave. Our Intech trailers are parked in Florida, so for much of the year, the local high temperature days are very effective at drying out the floor if there was a spill or minor leak. You don’t have a ramp door to invite a leak, so that is a plus. All of the black poly that we had to slit and fold down to air out wet wood from the Explore’s door seal leak was still strong, not weakened by the seven years time in place, or the water entrapment above it.
I'm in the same situation as @Kevin Lumney considering a SOL Dawn as a replacement for a near zero wood content teardrop style [TAB 320S]. The Solid NoFlex Floor; plywood is one of two construction choices inTech selected that concern me.
The TAB has a similar black water barrier material on the bottom side of the floor. The TAB also has an additional road debris guard / wind turbulence guard so road spray does not directly reach the floor underside. Yet during my 50K miles of travel with many rain/snow season adventures water did get into the floor composite. However there was no Rot, no softness as the floor structure contains zero wood . . . the added weight of the water did damage some floor support but no rot. Fully drying the floor and underbelly made the repair simple.
My point being sealants and other water intrusion prevention methods will fail.
With wood there will be real damage, frequently difficult/expensive to repair.
So the real question is how frequent are InTech Travel Trailer Floors failing due to water intrusion.
Additional feedback from current owners would be very helpful.
Second construction concern overview (un-related to this thread)
Side wall and roof R-Value must be very real-world poor and not near the sales literature claims.
  • all the "studs" and "cross-member" being Aluminum plus the large window areas mean a high percentage of the wall area has zero or near zero r-value.
  • while the remaining wall area only has air-gap insulation. The bubble wrap does help some; mainly in hot weather but is far less effective in cold conditions.
So are these really 3-season trailers or an extended summer season trailer?
A factory tour video and different question keywords in Google AI searches indicate the floor material is not plywood and is an advanced OSB most likely 'Dry-Max' or similar which is engineered to resist moisture more than standard OSB with less swelling or water intrusion at the edges.
Still a concern as nearly every other RV manufacturer has shifted to a no wood component floor structure. But it seems inTech is using the best available wood product.
Search References:
That would be Huber Advantech or a knock off. It really is good stuff but not infallible.
