They certainly didn't leave you any extra IMHO. My GVWR is 20,000 and they put three 7,000 pound axles under mine.My 5 er has tandem 5100 lb axels with a dry weight of 10010 lbs and a gvwr of 12000 lbs. Did the factory undersized my axels?
That’s what they are telling me but it’s all so close that it seems like they would just go ahead and put the 6k axels on. They can’t be that much more money.So if you have tandem 5100# axles and a 12k GVW then the rest of the 1800# weight is carried on the pin.
What is the load rating of the tires?Already put 6k miles on the original tires. Replaced them with Goodyear endurance tires.
You shouldn't need 'G' rated tires. Goodyear Endurance 235/80r16 'E' are rated for 3420 pounds each @80 psi. https://www.goodyearrvtires.com/pdfs/rv_inflation.pdfI would be more worried about what rated tire they let it leave the factory with. If your tires are below a G rating you should load everything up and run across the scales. When you have your axle weights pull up the tire manufacturer charts to see what psi they should be at and where you stand.
Just be sure you never exceed limits and you should be OK. You'd be surprised how heavy "things" get over time.... CAT Scale Apps | CAT ScaleSpecifications Definitions
GVWR (Gross Vehicle Weight Rating) - is the maximum permissible weight of the unit when fully loaded. It includes all weights, inclusive of all fluids, cargo, optional equipment and accessories. For safety and product performance do NOT exceed the GVWR.
