Question Atwood thermostat
Diane3075
Sioux Falls SD
American Coach
American Eagle
525 Deisel
We have a 2006 American Eagle with a Atwood thermostat #33910. It’s a 3 zone unit. It’s very difficult to read and we’d like to replace it. Does anyone have any advise on which one is compatible? And will we need an electrician to install it?
Hi,
Wanted to know if you got a replacement for the Atwood? I was waiting for Micro-Air to release their Atwood replacement thermostat, but it only replaces Atwood Air Command model. I have the same thermostat as yours, I have a 2005 Heritage coach.
Thanks,
Wayne
Hi,
Thanks,
Wayne
I installed the Micro Air and replaced all three control boards in ac units with wiring to get it to work
i used original thermostat wire change cat5 ends and installed ne w circuit boards in each a/c unit A/C units are the same where you located?
Thanks, that was my question. New control boards to interact with different thermostats. Still, good job getting it all working. Multiple units run on same Tstat is a bear sometimes.
I am in the Chattanooga area.
im in st john in i travel back and forth to pensacola in your area once in awhile anyway the job is not that hard
I have a 2007 Tradition with the same thermostat and I am looking to install the Micro-Air as well. I had seen the video a couple of weeks a go but now it is private. I need some direction on doing this. Part numbers and vendors if posable.
I have a 2007 Tradition with the same thermostat and I am looking to install the Micro-Air as well. I had seen the video a couple of weeks a go but now it is private. I need some direction on doing this. Part numbers of control boards would be great and vendors if posable.
Not sure if I understand correctly, but when I replaced my thermostat with a micro-air I used their website. It walked me thru and had pictures. Mine was simple plug and play. I have 2017 American Dream and also replaced one on a 2015 Entegra Aspire.
I did not replace an Atwood thermostat, mine was an Coleman - apologies for not reading the entire post.
