MarkMaxPayne
- May 24, 2023
- Beaverton, OR
- New Aire 3543
- 36'
- Spartan
- Fiat 500 Turbo
Hi everyone!!!
I recently purchased a 2023 Newmar New Aire and am having some issues with the generator starting on the first try either manually or via AGS. The rig came with two Lithionics batteries (640AH combined) and AGS is set to come on at 30% charge left from the factory.
Whenever I try to start my generator, either manually or via AGS, it doesn't start the first try. It'll prime the fuel, crank a couple of turns, stutter as it tries to catch, but not fully start. This causes a generator fault. If I manually tell it to try starting again, it'll catch right away that second try and run with no issues. However with AGS, are there settings to either prime longer, crank longer, and/or try again? It appears with the AGS once you get a failed start and fault it is out of the picture until you manually reset things so it can try again. As it stands today, it will not auto start and run to then recharge my batteries on its own.
Best,
-Mark
Best,
-Mark
