- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
I put my two Tempsticks back in play as I had them removed for a while. My solar setup has temp sensors I can run so it's monitoring temps but I reported an issue to the Tempstick manufacturer I was experiencing and they sent me a replacement as they have a newer model so I've been testing. I put one back in the wet bay as I had before and I also put one in the forward right basement back wall to see what the temps are in the basement in super cold weather ops. I'm in Flagstaff where the temps are down to the single digits to mid teens at night.
Interestingly the forward basement area is within one degree of the wet bay at around 51 degrees F. The wet bay has it's own heater tied into OASIS and then there are other heat sources that are helping matters from the OASIS unit putting off heat from the burner and the Inverter which can maintain high temps from normal operation. Nice to know the basement is nowhere near freezing in these conditions so fluids we keep in there are not freezing. This is also where I temporarily store my On The Go Water Softener as the left rear basements are not heated and it freezes in there (Ventana - no side radiator).
