- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
Yes, you have to pull forward which is not a big deal to me. Pump diesel, which I leave the engine running, pull forward, pump DEF. It's all a matter of personal pref but if you don't trust pump DEF do you trust pump Diesel? Why any difference? Just like any fuel or DEF for that matter, I'm sure it has regulations that govern the filtering, storage, etc. If they offered box Diesel would you use that instead?You're probably tired of hearing me say it but I never use pump DEF in my coach. To many reasons not to and its of no benefit to me to fill at a truck stop - it takes longer, I’d have to move the coach since the DEF fill spout is 30’ from the fuel fill, and with jugs I can fill at my leisure when stopped anyway. And since I get around 300mpg on DEF its pretty easy to plan ahead, buy enough fresh DEF for a trip and not over buy.
I personally think the box vs pump is overblown but it doesn't matter. Everyone does what they want to do. We can all nay say either way. We just hope whatever we are getting from whatever source is quality and not going to cause us any problems. My guess and only a guess is a lot more consumers are using pump DEF (i.e. truckers) than boxed products so if there is going to be a problem it's going to affect a lot more. It sucks either way. These RV myths are always interesting to read, just like the always keep DEF full (which I also don't do, what's the net age of your DEF after 5 years?) vs. cycle it at 1/4 to 1/2 DEF levels as I do. Again, do what you want in the end.
In @lostinfla's case, it sucks, whatever happened or if the DEF was contaminated. Bad deal!
Moral is: I have to trust the fuel coming out of the pump for my car. I have to trust the fuel coming out of the pump for my plane. Why does this change for RV with diesel or DEF?
