FYI Call me crazy, new engine.
tileman
tile-man
Lecanto, Florida
Fleetwood
Storm
We've owned 4 class A motorhomes. Several years ago we found one that suited us perfectly, a 1996 Fleetwood Storm. We've owned it about 20 years. It's taken us across the country from Florida to California 8 times. We frequently take off for 3 months and just drive around the country. I've replaced the stairs, water heater, air conditioner, microwave and I can't remember everything I've replaced or repaired. To be fair, I've replaced the water heater, air conditioner, microwave and many other items in my house. On my last trip I was traveling through Mississippi on my way to Florida. I thought I heard a tap, tap, tap. tap, By the time I got to Florida the tap was louder. I took it to my mechanic. He said it's in the bottom, you might need a new engine. We can't do that. You'll have to find a shop that can work on it. I called 3 large auto repair shops no luck. I called a local RV sales and repair facility. "We can't do that." Out of desperation, I ran an ad in a county forum "I think I need the 454 engine in my motorhome replaced" Several back yard mechanics gave there phone number. One person simply wrote "I can do that". I private messaged him. He's a mechanic at a shop called "American Diesel & Hydraulic" I took my motorhome there. I saw heavy duty lifts, a few trucks and a class A Diesel pusher. I'm waiting for the price. Call me crazy, I'm getting her a new engine.
So your in Florida then. To bad, If you were in Deming NM I have one with about 70000 miles on it that you could get for close to nothing.
Not crazy at all! If this coach fits your needs, go for it!
I’ve heard of several people having problems getting gas engines replaced in coaches but not sure why. Rebuilding a 454 is nothing special, so it must be an access thing; motorhome engines are tucked away in some pretty inaccessible places.
TJ, Yes I agree, it must be the access. There is a place in Phoenix (Glendale) that does RV engines reasonably I have read. Of coarse that doesn't help. Here is a video
My first thought was "Get another RV" Then my wife pointed out all of the upgrades we've done to this one. So we decided to pay for a new engine and keep this one.
I would discuss a rebuild vs a crate engine with the shop.
If your 454 is a carb engine, an upgrade to a Holley Sniper will bump the hp and mileage a bit.
Its only money...................
efi
There is a place called National Cylinder Head in Orlando Fl. They rebuild/exchange engines pretty much like an assembly line. Everything gets replaced, then tested on test benches and tuned before given to the customer. Years ago when I lived down there I had a small block GM engine in my Sea Ray blow. I pulled it out and gave it to them and in about 3 days it was completly rebuilt with replaced heads because of cracks they found for about $800 with 6 months warranty on marine engines and 1 year for auto. Now that was many years ago so price would definitely be higher. They also have a big shop there if you want them to do the work. A friend of mine used them not too long ago so they are still around. I believe the son now owns it.
I don’t know about the quality of there work today, but back then I was happy.
I'll ask the mechanic to check that out. I believe he's looking at options for me.
Factory remanufactured or crate engine or you better know exactly who is doing the rebuilding which normally means a patch job. So far I have not saw any rebuilt engines, tranny, differential or transfer cases hold up. That's just a hoax to get your money and cheap out. Also you will have strict guide lines to follow to get your warranty. I have denied most warranties for customers cheeping out and not replacing the entire cooling system. Number one engine failure is running hot, also you will need new oil pump, engine oil cooler, radiator, t stat ,heater core, all hoses, all engine pulleys belt tensioner and belts. One old part failure on the cooling system and no warranty on the new engine. Buy only new factory OEM parts not remanufactured parts they are junk and will kill the new engine. Reman water pump cost the last guy a extra 5000.00 for 2nd new engine and engine oil cooler again. After you figure the total cost it does not seem so good to do. You got to be in the ten grand range. Only you can decide if its worth it.
