Administrator
- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
Just as we pulled into our spot for the night, our entry step started acting up, extending/retracting repeatedly all by its lonesome. When the weather dried up, step started working.
Could be your connector connection to the the motor. I bought conductive grease and coated the plug (male) with that.
I think I read on the other forum that the gate closed on a coach as it was pulling through which tore up the coach and the gate and Newmar had to fix the paint on the new coach. It was something about a sensor failed on the gate or something.Couldn’t agree more, TJ. So simple with today’s technology. After all, you can go into a restaurant and they’ll text you when your table is ready!
Newmar could knock it out of the park with a simple QR code badge for access, rather than relying on long codes with VIN and whatever else for gate access. I wonder if that didn’t work for someone since one of their brand new gates has been complete torn off!
At the minimum, a fresh set of instructions, map, and even a WIFI code would have been nice. I will be kindly giving them these suggestions and know it would help if others did the same.
Sent from my iPhone using Tapatalk
