Carpet Removal
Michigan
Winnebago
Sightseer
32’
2016 Toyota Tacoma
Is the carpet in a motor home typically tacked or glued down? I have 57 reasons for getting rid of our light colored carpet. I removed the unsightly carpet from the engine cover in our Class A and replaced it with soft vinyl to match the dash. The carpet was glued and was very hard to remove from the fiberglass doghouse. Should I expect the same through the motor home?
Welcome to RVForums @Sunshyne. I don't know the answer to your question, others may, but I wanted to welcome you aboard.
WA, MT or somewhere else!
Mountain Aire 4047
40'
2014 Honda CR-V
Welcome, @Sunshyne, glad to have you here. As to your question, I suspect different RV manufacturers may each do it differently. Since it appears that you have a Winnebago product, I suggest that you call their customer service folks and ask if they can provide that information. Worth a ry.
No Where In Particular
Dutch Star 4369
43’ 9”
2016 Colorado
Welcome to the forum @Sunshyne. I am not sure on your coach as I think @TJ&LadyDi is correct that each manufacturer may do it differently. I can says that on a previous motorhome we had carpet was installed using tack stripes, this was a 92 Pace Arrow.
Prince William, VA
Ventana 4326
2019 Jeep Cherokee Trailhawk
Expect the worst and hope for the best.
  • Like
Reactions: Jim
Nothing a credit card can't fix :)
Jim
North Carolina
Tiffin
Phaeton QTH
2016 Jeep Rubicon Hard Rock
I have done a couple of motor homes and yes, it will be tacked down mostly. There will be some areas that are glued too but I used a pair of channel locks to grab onto the carpet and pull it off.
Expect to be pulling out thousands of staples out. I used the same channel locks to pull most of them out. Some of them will just need to be beat down flush with the floor. Just take your time and keep thinking of how good it's going to look when your finished. And take pictures so we can watch the fun from a distance. :)
(Note: Be careful of taking advice from Neal or you'll be driving around in a new 40' Ventana.)
Good luck, and welcome to the forum!
Jim
Florida
CanyonStar
39' 11"
Demco KarKaddy 460SS and VW Passat
Howdy, you are not alone wishing to remove carpeting. After a quick internet search, many folks have removed the flooring from a Winnebago. Most report, as you guessed, It Ain't Easy. But certainly doable. Good luck. Sounds like a fun project.
Michigan
Winnebago
Sightseer
32’
2016 Toyota Tacoma
Jim
Thanks Jim. it seems my choice is new flooring. I can't justify a 40 footer!
  • Like
Reactions: Jim
Prince William, VA
Ventana 4326
So I’m also ramping up to do this as well as we absolutely despise carpet with a completely irrational passion. If there’s one thing MapNerd hates, it’s carpet in almost any form. Rugs are okay.
Anyway, I’ll share my approach in case it helps anyone else. Our rig is new and as such, we have tile on the main floor and carpet in the slides. However, we really only have carpet in the FWS as the kitchen slide and bedroom slides are covered by cabinets and the bed so there’s no carpet there at all. We considered installing laminate or even engineered but ran into two problems:
1. It’s really hard to find a good match to Newmar’s tile unless you’re using that tile
2. The Ventana has electric slides and as a result, my slideroom floor is not flush with the main floor. It’s raised by about a 1/4” - 1/2”, so installing any laminate, tile or hardwood in there, no matter how thin is going to make that transition worse.
So what I’ve done is taken the 4 extra tiles I got from Newmar when I picked up my rig, and I took them to an industrial printing business where they have massive, high quality scanners. Triangle Reprographics in Orlando is scanning the pattern of each of my four tiles as we speak.
Once I have those tile images, I’m going to toss them into graphics editor on my computer (eg. Photoshop) and create an very, very large image - one the length and width of my FWS. I will paste those images into the graphic, repeating them in the same pattern as the main floor, a basic 1/2 offset pattern. I’ll space each image 3/16” from each other, end to end and side to side and set the background color of the image to the same color as my main floor’s grout and I’ll randomize the four tile patterns so that the same tile is never next to itself in the image. This will give me a nice little image of a floor with my exact tiles.
Then, I’ll send that image to Graphic Image Flooring where it will be printed onto a vinyl flooring sheet, rolled up and sent to me. I’ll then unroll it, let it acclimate inside the rig for a day. Remove the furniture, then the carpet, clean the floor, trim the vinyl and glue it down, trim out the edge of the slide floor, then reinstall the furniture.
  • Wow
Reactions: Jim
I asked Newmar about custom options to do something other than carpet and they told me no. Now that just means something they're not willing to do. I am the rare one I'm sure that I actually like my carpet. I like my bare feet on it when at the dining table having coffee reading the eNewspaper (RVForums.com of course). Sure, I'd love to have all tile but it's not the end of the world for me.
It's funny as I know where you are with your coach and getting acclimated as I have been there. It's amazing how my views and opinions have changed now having been in it 3 years. I'm very happy with my Ventana as designed and content with it without any desire for something new.
Edit: I started this reply really just wanting to say I'm anxious to see what you come up with and how your mod turns out. Not sure how I got into the above. Sounds like you have a nice plan and I look forward to your end results.
Prince William, VA
Ventana 4326
Oh yeah? Show me your RV wish list on Amazon...
Prince William, VA
Ventana 4326
Don’t worry @Neal. It shall be shared here. I think it’s going to turn out awesome but we’ll seee....WE’LL ALL SEE!
...and now back to our regularly scheduled programming of @sunshyn’s carpet replacement.
Jim
North Carolina
Tiffin
Phaeton QTH
Wow, I am truly impressed.
Jim
North Carolina
Tiffin
Phaeton QTH
Thanks @Jim. Just wait until you see how impressively I mess it up though...:D
Something tells me that's not going to happen. :) Would love to see some before and after pic's though. (y)
Michigan
Winnebago
Sightseer
32’
2016 Toyota Tacoma
Map Nerd:
That’s an impressive amount of planning so I think it will turn out fine.
