Buly
- Nov 3, 2019
- TGO Titusville FL
- Dutchstar 4369
- 2014 Honda CRV
It was probably a bad crimp connection. A bad connect will get hot and catch on fire. I had the same thing happen to me in my house. I had a connection at a wall socket that was not tightness down when installed. It worked fine for about 8 years! Then one day I smelled smoke and saw the socket smoldering. Breaker did not pop because it did not reach the 20 amp threshold.The mobile tech could not figure out why it happened. He fixed the wire and for now it's a mystery. It doesn't appear to be getting hot. Thinking I'll add another smoke detector back there to join the family of four detectors that I already have in the coach - just in case.
I took out the fuse. Had a scary moment as the KIB panel went completely dead after I put the fuse back in so I did it again and it came back on.
That would scare the hell out of me!Wow, I do not think the burning wires would have opened the door, were any fuses burnt? If not it’s even more concerning. Were any of the wire lugs loose when the tech removed them?
