Question Charge Line
Neemer
Crayon Eater
Virginia
DSDP 4326
ISL 450
I’ve always had a charge line on my toads, and they always had both a positive and a ground wire. My first was the old Toad Charge system (which no longer exists) and the second is an RVI system.
I purchased a Roadmaster charge line kit for my newest toad, and it has only one 14 ga line to carry the charge from the motorhome to a fuse/diode and on to the toad’s battery.
Why wouldn’t this Roadmaster kit also need a ground? Why the difference?
You should already have a dedicated ground connecting your towed to your coach via the light wiring. You should only need one ground.
Most will have only the 12v positive from the supply and will depend on the towbar to make ground. But, the reason for the ground to the battery is on the more expensive kits that have better circuitry for overcharging, LED diagnostics, etc.
I have the old brake buddy but just bought the Blue Ox which is 3x more, but has some built-in safeguards. With the squirrely AGM and electronics, I’m gonna hedge my bets as much as possible.
This is what I bought for $98, still a lot cheaper than the new RVi for $140.
Interesting. Thanks guys.
The towbar did not provide a ground for me so I had to add a ground wire. I was using the 7 pin to run magnetic tail lights so no ground there.
I would always add a wired ground. Depending on a ground connection in the tow bar which is being jostled and bouncing a bit, will have very small drops of connection.
With today’s sensitive electronics I don’t want to subject those to hundreds of power fluctuations during a tow.
Safer to just add a wired ground.
I am curious what the folks claiming the towbar is used to make the ground.
Are you using the 7 pin connection to the toad?
What is your connection plug to the toad? 7 pin, 6 pin, 4 pin?
Just trying to figure out why any one of those are not carrying your ground. They all are using white as a ground
