I did a little quick research and it most likely is FMI 18. Anyway, this is fairly common, and its important to do the simple and cheap things first. Change the DEF, change the DEF filter if its been a while or if it has been sitting for months without being driven. Those are cheap, its an easy job, and its normal maintenance anyway.
Your book may show a 200-300k mile interval on it, but sometimes the coach don’t read the book. Actually that interval may work for trucks that drive every day, but the way we use our coaches is different and it should be changed annually.
So those are two quick easy things you can do before spending money and starting parts swapping. Then give it five or six ingition cycles to see if it clears. It wont clear right away without code re-set equipment.
Also don’t get roped into the forced regen theory. Regens happen in the DPF which is after the SCR so it can’t have any impact on NOX sensing upstream. Its important to keep up on the DPF and do your regens, but it wont slove this problem.
If you do nothing, you will eventually experience derating and it will probably be in a couple hundred miles or less. So its improtant to get on this and see what’s going on. FMI 18 means low severity, but that’s for now. It can, and probably will change, and not for the better. You might already be at 25% derate and just not notice it. You wouldn’t unless you were towing heavy and/or climbing long steep grades.
So thats it for now. More codes would be helpful and you may need a good code reader for that. Also the ability to re-set emissions codes is nice. I use OTR Diagnostics for that but there are other non-subscription options available.
