Joe Hogan
- Nov 3, 2019
- Florida
- Dutch Star 4311
- Spartan
- Cummins
- 2018 Ford Flex
A simple conversion between inch pounds and foot pounds:
Here is a quick and easy way to convert torque measurements when you are dealing with inch-lbs and foot-lbs.
It’s a simple solution but one that can prove to be extremely important if you need to make a quick conversion.
From Tengtools:
Using the above diagram, if we want to convert 1200 inch-lbs to foot-lbs we do the following quick calculation;
1200 ÷ 12 = 100
Using the above diagram, if we want to convert 200 foot-lbs to inch-lbs we do the following quick calculations;
200 x 12 = 2400
From Tengtools:
Torque wrench conversion method
If you want to convert inch-lbs to foot-lbs, you take the inch-lb number and divide it by 12. Likewise, if you want to convert foot-lbs to inch-lbs, you simply take the foot-lb number and multiply it by 12.INCH - LBS | FOOT - LBS |
12 | 1 |
120 | 10 |
1200 | 100 |
2400 | 200 |
1200 ÷ 12 = 100
200 x 12 = 2400
