MapNerd
RVF 1K Club
- Nov 17, 2019
- Prince William, VA
- Ventana 4326
- 2020 Ford F-150
- Yes
Wow, lots of great food for thought. So a couple of things happening now.
1. Four corner weight is happening tomorrow. So I expect my pressures will drop on the after doing that and knowing exactly what pressure to use. I’ve been running at max psi as it came from the factory (I know, I know...). Found a spot nearby where I can get my four corner weight.
I don’t have my TPMS sensors on the stems because I ran into an issue with the valve stem extenders on the drive wheels not giving me enough space. So it’s not a tpms issue.Ordered longer valve stem extenders - single piece they will be here tomorrow and also get installed.
Also did a thorough inspection of all tires, outside, tread and inside. Got nice and dirty crawling around like a pig in the mud, but couldn’t find any tire damage and played with each valve stem to see if I could detect and leaks, couldn’t really find anything of note.
Hopefully, between getting the pressures calibrated to the weight and swapping out the valve stems, the issues will be resolved.
