Want to connect pit boss grill to the TT propane with a dual stage regulator. From what I've found online, can be done either before or after the regulator. I've been trying to find connectors to do either, with no luck(just frustration). Please help!
Keep in mind your grill won't like having a regulator on it when you hook up to the trailer supply line. Your trailer supply line is already regulated down to 11" of water column. The regulator on the grill will cut that pressure back a lot more.
