Tip Cummings Warning!
Igot 1999 fleetwood American tradition something is runing my battaries down and i have every thing cut off. Is there a electical problem that might be a comand problem in a old coach?
It could be 100 different things.
Unless you know how to isolate the draw
You may have to take to a place that sells a lot of batteries, and they may have someone there that knows how to test.
50% of the time is a light like a glove box, but here again, it could be anything.
If you can measure the draw from the battery with every thing off, you might try shooting one fuze at a time off and see if it stops it.
But all your doing is isolating the whole circuit, but it will give you a starting point.
Assuming you're talking about your chassis/starting batteries. Get a digital voltmeter and make yourself familiar with operating it. Using the AMP measuring setting, disconnect your battery and connect the meter between the battery and the cable you just disconnected. You should see a current reading on the meter. Now, get in your fuse box and start pulling fuses until the current reading drops off, anything above about 50 milliamps will drain your battery in a few days. when you find the fuse that makes the most difference, make note of what that fuse is for and go looking. Map lights, glovebox lights, underhood lights, dome/courtesy lights, and sometimes mis-wired aftermarket stereos/cb radios are you usual culprits.
