- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
Newmar, your coaches are not year round friendly. Where you are you know there is snow and snow and Newmar coaches do not work for many reasons. For this I hope you will improve your design so that your wonderfully insulated and heated coaches can go anywhere.
- Slide toppers do not work with snow. They don't roll up when a slide retracts, they fold up, they ice up, they are an epic disaster. Threads come out, they tear. You need to rethink this or even do away with slide toppers altogether.
- RV's in the north use heated fresh water lines. They have a blue hose contraption that plugs in and connects between the coach and city water connection, which is heated. My suggestion is to offer a separate inlet for a fresh line connection to fill the fresh tank that could be used with a heated water line separate from the city water reel. This could also offer a manual fill opportunity for those boondocking that bring in jugs of water as currently you need a pump setup to get water from other sources from jugs, bladders, etc. to the fresh tank. For heated water lines offer an outlet to power the heated line from the coach side as the campground may be using up the power connection to heat their city water piping.
