Dometic basement cooler mess (CF-80)
The other day I noticed yuck at the bottom of my Dometic CF-80 and thought a beer bottle broke. Not surprised, always wondered how the vibration would affect the contents of the cooler which is mostly bottles and cans.
Yesterday I did the next chore on the list for this cleanup stay as the first stop out on the trip which is to empty and clean the cooler. No run fo'sho! Took everything out, unplugged, removed the cooler and did the cleanup. Disgusting. It was actually a beer can, actually multiple beer cans ruptured. I had them on their side and stacked. I'd say at least half the bottom row had ruptured.
Cans placed in vertical this time and we'll see how things go. I'm still not impressed with the cooling wondering if I ever needed it in freezer mode if it would freeze. I had it set to 28F and my bottles of water were not frozen, cold, but not frozen. The gauge showed 31F as the actual temp on the side of the cooler. I dropped it to 26F and will see what happens. I'll give it time having had it out yesterday but I know some mention using this as a freezer. I wonder what temp you're setting as the setpoint to actually get to freezing the contents?
I know that it is not completely even. I keep ours at 33-34 (but have had one or both sides on freezer mode at -5). Recently, after it had sat for a few weeks full of water bottles, I was really surprised to find some of them frozen completely solid, a couple with a little ice, and most, just really nice and cold. The really surprising part was that the frozen solid ones were not necessarily the ones at the bottom or side (some were).
I've been running the temp down and monitoring. I went down to 20F and my bottles of water on top are still not showing ice or anything near freezing, but they are cold. I think the items on the bottom will freeze, the items at the top likely not. I'm not sure how the cold air circulates in these coolers but it seems the colder area will be at the bottom.
I set mine to 35 but figure it's probably closer to low 40's. The beer is warm so now I consume less. This cooler now saves me money.
In all seriousness, I have yet to try it in freezer mode. Will do that next year when we take a long trip and need the freezer space. I'm hopeful the food will stay frozen. Now that I say this, I guess it's time to test this out before relying on it as it does seem to run warmer than the temp setting.
I have used mine in freezer mode. In full disclosure, I put frozen meat in at the start of a ten day trip. Getting in it multiple times during the trip everything was still frozen when we got home.
I've always used my CF-80 as a freezer since i bought my coach in 2016. I use a set point of 0 degrees. What I've found is that the CF-80 maintains the freezer set point when the coach basement temperature is less than 80 degrees. When the basement temperature is between 80 and 90 degrees, the CF-80 will maintain a freezer temperature of 5-7 degrees. Above 90 degrees, the freezer temperature increases to between 11-15 degrees. I experienced this first hand last week in Moab when the daily temperatures were well above 100 degrees. I turned off the oasis and ventilated the basement at night with fans to minimize the basement temperatures. Even with the higher freezer temperatures my items remained frozen.
