Dometic toilet leak
AbdRahim
BayStar 3626
37’
Ford
V10
None
I have a Dometic 310 toilet. Water leaks from the pedal only after holding it halfway down to fill the bowl. It does not usually leak when just fully pressing to flush. Newmar just replaced the valve a few months ago, but the problem is back.
Anyone experience this and find a solution?
After reading your post on the campground minimums, I would say use the head more 🤣.
I hook my toe under the pedal and lift.
Yes ... definitely needs more solids in it!
When the pedal is all the way back up after filling the bowl, you can hea the water running into the pedal for a few seconds then onto the floor.
I have seen on other forums where replacing the valve solved the problem, but apparently not in my case. Replacing the entire toilet does not sound appealing.
any other ideas or experiences?
