Fairly cold temps coming to N. Florida. I have a new 2022 Roadtrek Chase. I am trying to determine best approach to draining fresh water tank. Is there an easy to find/use drain plug?
I have a 2007 and had to remove the anode on the water heater using a 1-1/16 inch socket. Really no problem except to find the socket. (Borrowed from neighbor). The Roadtrek manual said see the water heater manual. The water heater manual in one place said to see the owner's manual. Back and forth, I figured it out. I would think the newer models have a more sophisticated way to drain. My Airstream has a drain valve - simple turn and it all drains out.
