Dumb Sealant Questions that's been asked 2 million times
Phillbo
RVF VIP
What does everyone use around doors and windows ???? Brand preference etc.....
I'm not pulling the windows out. I just have a couple areas where I need to remove the existing sealant and redo it.
I can't help you. Never seen a short cut with good results.
Many manufacturers add silicone around the perimeter after install
I was under the impression you never use silicone on an RV. non sag lap sealant?
I have used "exterior" silicone for years. Black, white and clear. It's just a bitch to remove when it needs to be redone. Anybody know of an easy way to remove it?
They make products that help but still difficult.
PROflexRV
This used to be $10.00. It does work well and you can paint it.
I that there was non sag and self leveling lap sealant ?
Huh? Lap sealant is for roof seams, bolts and penetrations. I answered your question for what is actually used, after installing with butyl tape. Many manufacturers add clear silicone around the upper perimeters
You posted "What does everyone use around doors and windows ???? Brand preference etc....."
So what do you think? If you have a leak, do you patch,or reseat?
That would be on a case by case basis.
Age of coach
Size of leak
Location of leak
Quality of substrate
