Dump tank
roadeagle
Using smart tote caddy for grey water for first time and find that after closing gate valve water does not seem to empty out of trailer drain...seems to be a vacuum hold water back. Tote is only 1/2 full and tote vent is open. ANY THOUGHTS?
Does the water quit flowing into the tote or does it keep trying to get a slug of air? What size tank are you draining into what size tote?
It seems to need some air to empty into tote.
Tote is only 18 gal and I open and close gate valve to dump 10-12 gals into tote. It is by no means full.
New or older RV?
Vent on roof plugged.
I reread your question, and I don't quite understand it. Do you mean that when you dump your grey tank only about ten gallons drain then it stops flowing?
