E-Bike update?
10thtp
Tool Texas
Coachmen
Beyond 22c li3
Ford Transit 350 awd
Eco boost
I just asked this question on an an older thread. Don’t think anyone is reading. I need the lightest serviceable e-bike I can buy. Price is not primary objective but, a consideration. I can not lift 65 lb bike upon rack. Looking at spec’s on Lectric XL base unit not 2.0. Weight list at 46 lb w/battery, battery 7 lb. I think I can handle 39 lb. The reviews are mostly on the 2.0 model that are all positive however it’s 65+ lb. Does anyone have experience with this base model or maybe something similar? All reply’s appreciated.
@10thtp We have RAD city step through e-bikes (i.e. full size bikes) and I use a Hollywood e-bike rack on the back of our toad. The bikes come it at 65lbs with the battery probably 5 or so lbs lighter without battery. BUT you don't have to lift 65lbs to get the bikes into the rack. I lift the front of the bike i.e. front tire / fork area and set it into the rack, then lift the back of the bike and set it into the rack. I don't know what the weight of the lift is but it's a pretty easy load process and a lot less that 65lbs.
I will have to try some of these load & ramp techniques. I’m 80 years old and have neuropathy that has limited my strength & mobility. I know 60 lb is out of my range. I think if I can get the bike close to 40 lb & use the one wheel at a time lift it will probably work for a while. Hopefully someone has purchased one of the Lectric Base models that only weighs 46 lb w/battery can tell me if it is a serviceable bike or just too light weight to be useable. It is primarily for my wife, I will ride very little, if any at all. Thank you very much for the reply.
I got a "dirt bike" carrier. The wheel base is close to the ebike and they have a ramp that comes with it. You need a 2" trailer hitch for it to fit into. No lifting. I modified mine with a post for better securing the bike. Also I got a barbeque cover to protect it from the rain when traveling or any time the weather gets bad at the camp site.
These range from 40 to 55lbs but a little on the pricey side.
Thank you for your reply. That sounds like it would work. My new motor home came with a bike rack built on the back. The rail’s about 30” off the ground, I will need to work with that .
Wow, super cool bikes. But you nailed it, a little pricey. Thanks
They really are nice and well designed - quite advanced over the typical e-bike. But one of those would create a security problem - you’d always be worried about it, and being on the road wouldn't do much for that lovey finish. So I guess not practical for the RV world - you’d really have to store it inside. But Ive been coveting them for about six months since I first heard of them.
Yes, it’s easy to forget until it happens. All the neat stuff we worked hard to get, there is some dirt bag that’s working hard to take it.
We just purchased the Lectric XP Lite that weighs 46lbs just for the same reason. We find these bikes perfect for us with our Tiffin Wayfayer. We can mount on our hitch Tule bike rack or we can fold it up and put in Rv. For the price and quality I believe you will truly enjoy the flexibility and weight. Compare the two on YouTube! Good luck
We purchased an Lectric XL Lite a few weeks ago for wife, she loves it. Plenty of power and speed 18-20 mph. I think I have this right, it does not have multiple gears, only one gear with 5 power selections for pedal assist or throttle only control. She just selects power 1 starts peddling, if the grade is too steep she just gives it a little throttle to help up the hill. So far power 1 is all she has needed so far, it will get her up to 16-18 mph on flat land. Super little bike, only 39 lb with battery out. The company is great to deal with. After using for a few days the battery power indicator dropped to 3 bars. When I tried to charge it, it would not charge. The charge port was damaged, I called tech support, explained the problem, the next day they sent a new battery. New battery works fine and takes a full charge. This bike is just what we needed for our little motor home.
Thanks for the report on the Lectric XL Lite, 10thtp. I’ve been looking at that bike for a couple months trying to decide whether to pull the trigger on it. Please post updates, when appropriate.
And thanks to you, Inerstate, on the info on the dirt bike carrier from Harbor Freight. My wife has an electric Trike, and I’ve been looking for something with a ramp. It’s a chore to lift that up onto my Hollywood rack.
My best to you both, Ed
Ed
If you’ve looked and considering the Lectric XL Lite, I think you can pull the trigger and not be disappointed. This is a very solid built little machine. It folds to a really neat little package that can almost get lost in a big rig storage bay (big “almost”). I would have already bought another one for myself if I could physically safely ride a bike. FYI a 65-69” cover fits perfect.
Terry
