Question Electrical Lithium problems
recox
Hello everyone,
I'm seeking some help to better understand my electrical system in my CamperVan. I have limited knowledge about electricity, but I'm eager to learn more.
The electrical system in my van was professionally installed. Currently, I have 3 lithium batteries (Vision SP12-200 - [link](https://www.cellpower.co.nz/shop/product/513843/a-vision-sp12-200a-lithium-battery-12-volt-200-ahr/)) connected in series, although for the tests and description in this post, I am using only one battery, with the others disconnected from the vehicle.
All the tests I'm conducting are with the batteries fully charged using the PowerTech MB3910 charger (which marks 13.17V). It's worth mentioning that after a recent road trip on New Year's Eve, the batteries were nearly drained, and their voltage had dropped to a very low level (around 2V, as checked with a multimeter). This caused the BMS system protection to activate. To charge them, I had to "jump start" them as demonstrated in this video ([link](https://www.youtube.com/watch?v=j2JjOpq50MI)) using a NOCO Boost 12V 500A Jump Starter - GB20.
I'm encountering several issues with my vehicle, and I'm hoping for assistance with the following:
1. **Water Pump**: I initially had a 25dpi water pump ([link](https://www.rvsupercentre.co.nz/flojet-3426-series-water-pump-11-lpm)), which didn't work well. I often experienced air bubbles in my water system, requiring me to manually prime the hose. I sent it to a caravan repairer for proper fixing, and they suggested replacing it with a 30dpi pump ([link](https://www.dometic.com/en-gb/professional/marine-solutions/boat-pumps/dometic-powerpump-pp1210-64063)). While it worked initially, it stopped functioning after a short road trip. The voltage readings for the pump are 11.18V (not running) and 11.68V (running), whereas the 25dpi pump never had this issue and reliably turned on.
2. **Battery Duration**: I have a 200Ah battery and want to determine how long it will last. To test this, I connected the battery to the van and used only the fridge (GASMATE 3-WAY UPRIGHT FRIDGE 62L - [link](https://www.gasmate.co.nz/product/62-litre-upright-camping-fridge/)). Here are my observations:
- Test A: I connected the battery at 6 PM, turned on the fridge, and the next day at 9 AM, the battery charge was nearly empty, as indicated by the Victron BMV 712 Smart ([link](https://www.victronenergy.com/display-and-panels/bmv-712-smart)). However, the voltage remained at 12.58V. The fridge was still operational and cool. After removing the battery, a multimeter read 12.69V, and I am currently recharging it.
All these pictures are part of Test A
- Test B: I connected another battery and left it running for approximately 24 hours (exact duration not remembered). When I checked, the electrical system, including the battery monitor, was completely off. After removing the battery, a multimeter showed 9.33V. Interestingly, the battery required another "jump start" to begin charging.
3. **Victron BMV 712 Smart**: I'm facing issues with the Victron BMV 712 Smart. The manual states that it should retain usage history for 45 days. However, every time I close the app or the system shuts down, it erases all data. Am I doing something wrong or is there a misconfiguration?
These pictures are for reference only, just one battery is in the vehicle in the tests.
Any help or insights regarding these issues would be greatly appreciated. Thank you in advance for your assistance!
Your batteries need jumped because you drained them to low!!!
3 way refrigerators are energy hogs!!!
So other than testing, and getting less than expected, what are the issues?
Hi thanks for the answer.
My other issue is the water pump
What can I do to understand why is not getting 12v in there? With the multi meter in the cables where are the fuses they read 12.60v
can be the cable or the switch ?
You have air leak on the suction side of the pump. That’s why you see the bubbles. That also causes the pump to loose its priming. Ideally the pump should be mounted close, or below tank level.
Check all the hose clamps and connections.
Like Buly said! Air bubbles indicate Air finding it's way into the suction side of the pump. Check all connections on the suction side. Strainer, connections, and cracks in the hose. Diaphragm pumps can run dry, and don't have trouble priming, you got the literature for the pump, so you can verify the suction hose is not to long.
As for voltage! Resistance causes a drop in voltage. Bad connections cause Resistance! Bad connections also produce intermittent failure. Top that off with the fact they are a fire hazard. It is important you check all connections back to the fuse for solid contact.
Thanks for your answers, I think I have a bad cable/connection as my voltage is correct but when I read the switch it has less than 12v
On top of that, someone told me that perhaps the problem is that my batteries are not fully charged, what do you think?
From what I can tell your batteries aren't being fully charged. Lifep04 requires at least 14.4 volts, I always charge mine to 14.6 volts. Your victron shows the max voltage reached was 14.16 volts (which is insufficient).
The mfg recommends charging at 13.6 to 13.8 volts which most chargers will be trickle charging at low amps for such large batteries. At higher voltage of 14.4 to 14.6 volts is when you will be sending max amps to the battery.
Many people recommend not to fully charge the lifepo4 batteries but it won't damage them I been charging my 220ah lifepo4 to 14.6 volts every day for the past 5 years, they are still working excellent.
These are the specs from the battery mfg. for your battery.
Recommended Charge Current 25A
Maximum Charge Current 50A
Recommended Charge Voltage 13.6 to 13.8
Charge mode CC/CV
BMS CHARACTERISTICS
Max Charge Voltage 14.4V-14.6V
Overcharge protection voltage 14.8V-15.2V
Maximum Continuous Discharge Current 100A
Discharge cut-off voltage range 9.2V-11.2V
Your victron is probably not properly calibrated, most coulombcounters have to reach max voltage (at least 14.4 or 14.6 volts whatever setting you set for max voltage) at least once to be properly calibrated. If your battery has never been fully charged to max voltage it won't know what percentage it is suppose to be at.
If my battery was reading 12.58 volts with no loads, it would be dead. For lifepo4 any voltage under 12.8 volts (no load) is 50 percent or less. Normal voltage for recently charge lifepo4 is always going to be over 13 volts (no load).
I don't think the powertech is fully charging the battery, at 15 amps, it would take 13 hours to fully charge to the powertech max voltage of 14.5 volts. When charging did you see if the max voltage of 14.5 volts was reached by the battery (on victron or multimeter). With lifepo4 you have to reach those voltages to get an idea if it is fully charge.
If there is voltage drop from the charger to battery, the chargers voltage LCD might be off, thats why its best to get the voltage reading from the battery terminal.
I suspect that you are in the correct path of the problem,
When the battery is fully charged and the charger stops, it looks like this
So it never reaches 14.5v.
The charger has many modes, I was using lithium. Do you think I should use Recover v12 or "CAR" Icon mode ?
LITHIUM 12.8V MODE (14.5V 15A): Long press 3sec. the MODE selection button, if the measured voltage is between 11.6 V and 13.8 V the battery is identified as a Lithium (12.8V 4-cells LiFePO4) to activate LITHIUM 12.8Vmode.
Then if you do not take any further action, the electronic system will automatically start the charging process together with the LCD display will flash at (with a current of) 15A. If the process runs without any problems,the LCD display will show the battery charging (bars will start flashing)until the battery is charged. When the battery is fully charged, the battery icon should be full and will stop flashing. The device now switches automatically into maintenance charging mode.
RECOVER 12V MODE (14.7V 15A): REACTIVATION OF DEEP-DISCHARGED 12 V BATTERIES USING PULSE CHARGING This mode is mainly suitable for charging 12V lead-acid batteries with a capacity greater than 50 Ah. Long press 3 sec.the MODE selection button, if the measured voltage is between 2.0 V and 14 V the battery is identified as a 12V battery to activate RECOVER 12V mode.
Then if you do not take any further action, the electronic system will automatically start the charging process together with the LCD display will flash at (with a current of) 2.6A. If the process runs without any problems,the LCD display will show the battery charging (bars will start flashing)until the battery is charged. When the battery is fully charged, the battery icon should be full and will stop flashing. The device now switches automatically into maintenance charging mode. The battery voltage has not risen to 12V within 4 hours, The error message appears and flashing on the display and returning to the standby mode.
OR MODES (14.5V 15A / 14.7V 15A):
Press the MODE selection button to select MODE or . After doing so, the corresponding LCD display or lights up.
Here is the manual:
POWERTECH MB3910 10 Step Intelligent Lead Acid and Lithium Battery Charger Instruction Manual
