- Jan 19, 2021
- Rosemary Farm, Grass Valley Ca
- Ventana 3427
- Freightliner XCR
- 6.7 ISB 360/800
- 2001 Jeep Wrangler
A 2A10BC should be standard issue. It’s enough to stop a small fire and if you have a fire too advanced for a 2A10BC you should just grab your valuables and abandon ship because even if you manage to put it out without injuring yourself, if the coach doesn’t get totaled and gets repaired, it will never be the same, you’ll have constant electrical issues from then on, and you’ll be living in an environment contaminated by the many toxic products of combustion.
I have the Newmar issued small extinguisher by the door and a 2A10BC in the one of the rear compartments on the door side. So I can stop a small fire inside and an engine or brake fire if I catch it in time. But prevention is really the most important approach because these things burn fast and even a small fire will do a lot of damage.
Regarding dry-chem extinguishers carried in or on vehicles, you should turn them upside down several times and shake them up a bit every couple months, and then have them serviced annually. The powdered extinguishing agent in dry-chem extinguishers tends to compact and solidify when the extinguisher just sits in a mount all its life and is constantly subjected to vehicle/road vibration, and then not deploy when you pull the pin and squeeze the handle. You’ll just get the propellent gas and maybe a little dust, which may be for the best, but probably a bit disconcerting anyway.
Also anyone who anticipates ever being in the position of having to use an extinguisher on an actual unintentional fire should get live-fire extinguisher training in advance. Its fun and informative and using a dry-chem extinguisher effectively is not nearly as simple or straight-forward as most people think. During an emergency is not the time to learn how to use them, especially if you only have one because more than likely the first one will be wasted during the learning experience.
