JeffAndPam
- Jun 26, 2023
- Alabama
- Fleetwood
- Flair, 34R
- 34'
I found an access panel on the side of the fuse box, and sure enough it looks like there's a metal box attached directly to the back of it (outlined in yellow):Generally, it is near the fuse panel as some are built into the fuse panel and some plug into the back of the fuse panel in a dedicated socket. Plus it feeds the fuse panel with large gauge wires, they don't like to run them far.
I'll disconnect power, pull out the fuse box and take a look. Thank you for your help.Hard to tell from the pic. It should have a 120v plug and 2 12v dc wires with a couple of fuses beside them
So house battery is located under the stairs. Looking under the vehicle, the negative cord connects to the frame, the positive cord heads in the direction of the chassis battery.Check near the batteries, it must have 120 vac to work and be hooked up to 12 vdc to charge the batteries.
