Floor replacement slide clearance
paudia
I have a 2007 bounder 38n. I am planning to put a luxury vinyl plank floor in the kitchen which is the passenger side. Can someone explain the process to raise that slide to clear the new floor ? The local dealer talked to me about jacking up the slide and adding a board where the slide comes in to get more height to clear the new floor. Plan on climbing under the slide tomorrow but any input would be appreciated. Thanks
Phil
Our slide 1999Dutch Star has rollers under slide and rolls right over new floor with no problem. Board closest to slide ducks under slide carpet. Floating floor with 1/2 inch round along edges.looks amazing.no marks from rollers.
We took our old final out and put new plank final flooring in. If you run the slide out out but not all the way. You should have a little room to work it in. If you slide it out all the way it seems to contact the top first and rotate the bottom down.
