- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
Things like disc brakes all around, 20k front axle, better marketing on service locations, and a joint partnership on the warranty effort, making it seamless for the buyer.
NHSO
That’s the way I understand it as well. Newmar is probably lowering the spec to increase their margin.Either FL or Spartan will build their product, within reason, to the spec Newmar lays down.
An admirable request but how could they do that? Newmar sets the spec. SP delivers a chassis that matches. If SP goes out and decides, Newmar said drum brakes and SP delivers a chassis with disc brakes, Newmar will probably reject it as it’s not to spec.I agree, newmar sets spec. It is for this reason this reason that there is very little reason to choose one over the other.
What I would like is for Spartan to figure out a way to offer something that is clearly (not subjective, but clearly) better than freightliner.
This should be in quality, innovation, and service. They need to make all 3 drastically better than freightliner.
This would be very good for all owners, as it would force freightliner to improve their product, starting a new battle where everyone wins.
2019 DSDP 4369 * Active Air * NHSO
Or, Spartan could tell Newmar that there will be an "uncharge" for substituting drum brakes for the standard discs! Wouldn't that be interesting to see how Newmar would explain an "uncharge" for downgraded brakes is spec'd?An admirable request but how could they do that? Newmar sets the spec. SP delivers a chassis that matches. If SP goes out and decides, Newmar said drum brakes and SP delivers a chassis with disc brakes, Newmar will probably reject it as it’s not to spec.
The only obvious lever I see for SP to pull is to build their chassis using those stepped up components all around, bar none. At that point, if Newmar specs with drum brakes for instance, SP would have to come back to Newmar and say “nope - we don’t build em that way. Discs or bust.” At which point, SP risks losing that chassis business from Newmar.
